Burning ISO Images
Currently Active Users: 1929
Discussions: 200,992, Posts: 2,379,902, Members: 246,360
Old May 5th, 2007, 05:09 PM     #21 (permalink)
Caveat Emptor
Rootstonian's Avatar
It's a DVD and I just tried to boot in on my Dell 2400...no joy.
Burning it now with PowerISO; seems like some decent software. I'll buy it if it does the trick
Rootstonian is online now   Reply With Quote
Old May 5th, 2007, 06:22 PM     #22 (permalink)
Caveat Emptor
That worked, but the server requires a hardwire and that's in the other room (not in my "Command Central").
Oh well, time to have Time Warner come out and rewire anyways.
Command Central is the boy's old bedroom, but he's out and married and I have taken it over. Her PC and router and desk are out in, for lack of a better description, the family room. We'll be remodeling that soon anyways, so I guess I'll have to pay for the rewire job. 1 story ranch, crawl space only so Time Warner will earn their money!
They pretty much just have to run the coax down to this room and then take a ethernet back (just in case we want a hard wire connection back in the family room).
Old May 5th, 2007, 07:46 PM     #23 (permalink)
to F@H or not to F@H ?
Cmptr-Gy-Dv's Avatar
you can still get to it over the internet,
i'm folding for techimo!! what are you doing?
Cmptr-Gy-Dv is online now   Reply With Quote
Old May 5th, 2007, 08:13 PM     #24 (permalink)
quickoldcar's Avatar
Send a message via AIM to quickoldcar
About your burning a bootable dvd.
Get poweriso
Open the server iso with poweriso.
Now look at the bottom if it says it's bootable or not
If it is just click the burn button up top and select you dvd drive.
Burn slooooooow as you can.
Best advice I can give.
quickoldcar is offline   Reply With Quote
Old May 5th, 2007, 08:24 PM     #25 (permalink)
Caveat Emptor
I did get the DVD to be bootable with PowerISO, nice software
The way my house is setup, I'm not ready to install this the way I want it to run.
Just need to spend a few bucks getting the house rewired and I'll be good to go.
Thanks again for all your help...this IS the best tech forum on the Internet!
Old May 10th, 2007, 03:26 AM     #26 (permalink)
I'm not sure If this is the question your asking, but you can use Alcohol 120% to create virtual DVD drives and then mount your image to access the disk.
P4 2.8 GHz
2 Gigs ddr
Windows XP Pro
Network67 is offline   Reply With Quote
Old May 10th, 2007, 09:43 AM     #27 (permalink)
Banned
Keymaker's Avatar
Send a message via ICQ to Keymaker Send a message via Yahoo to Keymaker
That or Daemon tools
Still don't understand how emulating a CD/DVD disk drives facilitates an install when all you need to do is burn the .ISO?
Virtualpc? Would this help too?
Keymaker is offline   Reply With Quote
Old May 10th, 2007, 09:44 AM     #28 (permalink)
Banned
Keymaker's Avatar
I have burned disk in 10-15 min. no problems.
Old May 12th, 2007, 12:07 AM     #29 (permalink)
I have had this problem.No explaination but here's what I did.
I chose 'bootable data disc' on the burner proggie.I put a floppy in that was blank and formatted.This made my discs bootable.
Does that help or was that so obvious that i should be heckled and have gum thrown in my hair from someone sitting in the back of the bus?
extitude is offline   Reply With Quote
Old May 12th, 2007, 12:26 AM     #30 (permalink)
If you want to make an iso bootable that isn't.
Best bet is Nlite program found here.
http://www.nliteos.com/nlite.html
I downloaded Boot files and add then to my iso manually with poweriso and then save. Basically it's the same stuff found on the floppies and adds this at beginning of the cdrom.
I uploaded the same boot files I use and they do work well.
http://www.zshare.net/download/boot-rar-pxh.html
burning an ISO image problem msterzer Applications and Operating Systems 13 July 31st, 2006 04:49 PM
iso images swell22 Multimedia and Audio 9 December 3rd, 2004 04:10 PM
Creating ISO Images DanGrease Applications and Operating Systems 6 August 21st, 2004 03:28 AM
burning an iso file emorocks83 Applications and Operating Systems 5 November 3rd, 2003 11:17 PM
Burning an ISO with Roxio CD Creator 5 dyer_maker General Tech Discussion 3 November 30th, 2001 10:23 AM
Is It Just Me? (3083)
Health Care Rationing (13)
Delete an OS (17)
Nvidia GTX 260 problem (10)
[F@H SPAM 11/16/09] ! 1/2 months to.. (40)
Internet Lost (5)
Print spooler problem (17)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (40)
Foxconn Blackops x48 MoBo (3)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
