PassMark Score Charts (updated)  | | |
July 21st, 2007, 12:10 AM
#101 (permalink)
| | Onii-san
| Quote:
Originally Posted by Prince Lalijama My processer was using 40% of itself before i benchmarked.
Ill restart my computer and retry later tongiht.
Where can i get a program that uninstalls things. I need one to remove some startup things. |
Its called add/remove programs and it is built into windows.
One by one the penguins steal my sanity. TechIMO Folding@home Team #111 - Crunching for the cure! |
July 21st, 2007, 12:50 AM
#102 (permalink)
| Quote:
Originally Posted by JLK03F150 I read the 8600GT benches about the same as a 7600GT in DX9, but it also supports DX10. IMO it should bench closer to a 7800/7900 card in DX9. | http://www.hwbot.org/searchMembers.d...CConsole%7C%7C
check those scores for a card that yopu say sucks =)
E8400 8.5x500=4250mhz 1.38v 24/7 ( 4.7-4.9ghz for benchs ) /Evga 780i
OCZ PC-6400 5-4-4-15 800mhz 1.9v / Corsair 620hx / 8800gt @ 740/1800/1000 24/7
July 21st, 2007, 12:52 AM
#103 (permalink)
| | Pet Me, Feed Me !!!
Prince, you can either run > msconfig & uncheck un-needed things from the startup tab, or you can use a program called CCleaner. |
July 21st, 2007, 01:01 AM
#104 (permalink)
| | Pet Me, Feed Me !!!
| Quote:
Originally Posted by ||Console|| | I didn't say it sucks, I said it should perform better without needing a 4ghz C2D behind it. At stock speeds with a stock cpu, this card should be able to beat a 7900GS/GT, IMO. But the Anandtech shows it can't do that.
The GTS can though, so it would be a good card for someone that isn't gonna push it to the absolute edge (like someone I know around here).
Edit: Make that 4.1ghz. HOLY COW !!! Didn't realise you pushed that far. I'll be lucky to bench at 3.9.
July 21st, 2007, 01:25 AM
#105 (permalink)
Add remove programs isnt finding what I need to remover. And also i hear windows unisntaller isnt a totally clean uninstall. Wether thats true or not I'm not sure.
I'm PL, I've come to suck all the intelligence out of this thread.
July 21st, 2007, 03:28 AM
#106 (permalink)
just did a quick run , it says it is a partial score cause i dont have a cd rom pluged in . but i scored 1012 @ 3.2ghz card @ 660/950 |
July 21st, 2007, 06:45 AM
#107 (permalink)
| | Reaper
CD doesn't add much, I'd estimate your score to be about 1100 or less. |
July 21st, 2007, 10:15 AM
#108 (permalink)
| | [_LEWD_COMMENT_HERE_]
| Quote:
Originally Posted by Prince Lalijama Add remove programs isnt finding what I need to remover. And also i hear windows unisntaller isnt a totally clean uninstall. Wether thats true or not I'm not sure. | Have you checked what's in the Start--> All Programs--> Startup list...?
I know it sounds silly on here, but sometimes can be overlooked.....
__________________ I've seen the light... It was green, flashy and attached to a Network Interface Card... Whenever someone says "You can't miss it" I invariably do... |
July 22nd, 2007, 05:07 AM
#109 (permalink)
| | voids warrantys
More Overclock
I wonder what's gonna limit me first. I'm guessing heat. It's running a little warm at 3.61Ghz, but I wanted to see what the score would be
But, another new score for me. I'm really wanting to score 600, then I'll give up.. |
July 22nd, 2007, 01:23 PM
#110 (permalink)
| | Reaper
How hot is it running? Smithfields and Prescotts can take serious heat compared to other processors. |
