Thread: finding mouse cursor position???
June 17th, 2007, 02:26 AM #1Junior Member
- Jun 2006
- 26
is there a small utility or a program i can use that will show my the coordinates of my mouse cursor?? I really, really need to find my coordinates of my cursor so can someone please help me
June 17th, 2007, 04:58 AM #2
go to control pannel, click on mouse properties, then go to the pointer options tab and click on the little box that says show location of pointer when i press the control key
i5 3750 | ASUS P75 | GTX560Ti | 8gb Corsair Vengence
PII 720BE X3 @ 3.7Ghz | Gigabyte 790GX | HD6850 | 8gb OCZ Reper
June 18th, 2007, 10:46 AM #3
That does not show (x,y) coordinates of his mouse
June 18th, 2007, 11:02 AM #4
My friend Google has a bunch of info.....Here's one:
http://yaldex.com/FSPageDetails/MouseCoordinates.htmImagine a world where dogs took bad owners to the pound...
June 18th, 2007, 03:49 PM #5
That works IN IT"S OWN PAGE, not on an outside windows.
If I wasn't so slammed today, I would have wrote him one, but Google results should turn something out fairly quickly.
October 9th, 2008, 11:26 AM #6Junior Member
- Oct 2008
- 1
Low Tech Solution with Paint
Hit the 'Prnt Scrn' button
Open Paint
Select Edit > Paste, or Ctrl-V, to paste the image.
Click the Free-Form select button (Dotted Star) to lock the image location
Move the Mouse over the location in the image.
Note the Mouse Coordinates in the status bar.Last edited by qptmgrossman; October 9th, 2008 at 11:29 AM.
October 9th, 2008, 11:59 AM #7
FYI - this thread is from June 18th, 2007
October 9th, 2008, 01:04 PM #8
That is pretty smart though..
August 8th, 2009, 07:57 PM #9Junior Member
- Aug 2009
- 1
yea I know this thread is yrs old but the screenshot method won't work because whatever graphic application offsets the coordinates, savy?
our good friend google did not cough up dozens of results and I could only find one that fit the bill, though I remember a small little app that had the coordinates in a tool tip.
Exact Mouse - Free software downloads and software reviews - CNET Download.com
2 week trial so not ideal
August 19th, 2009, 10:14 PM #10Junior Member
- Aug 2009
- 1
Hey,
I found a good way to find the coordinates of the mouse.
1. Download: AutoIt v3
2. From the Start menu, go to AutoIt v3 > SciTE Script Editor.
3. Paste this script code into it and save it:
4. Now go to AutoIt v3 > Run Script and choose the script you just created. The icon will show in the system tray (bottom right).Code:HotKeySet("z","jPos") While 1 Sleep(100) WEnd Func jPos() $jPos = MouseGetPos() MsgBox(0, "Mouse x,y:", $jPos[0] & "," & $jPos[1]) EndFunc
Now when you press the letter 'z', it will display the mouse xy coordinates in a pop-up box.
Source: coordinates program ? - AutoIt Forums
ChrisLast edited by Chris4; November 7th, 2009 at 01:46 PM.
September 15th, 2011, 01:21 AM #11Junior Member
- Sep 2011
- 1
u can ref here.
Tryit Editor v1.4
easy to understand LOL!!
Gud Luck!!
Mouse Cursor Dissapeared!
By The_Shooter in forum Technical SupportReplies: 9Last Post: January 18th, 2007, 02:27 PM -
Problems with mouse cursor
By ok.player in forum Technical SupportReplies: 0Last Post: October 5th, 2006, 12:24 AM -
Default cursor position.
By RO233 in forum Webmastering and ProgrammingReplies: 0Last Post: September 5th, 2006, 02:16 PM -
Controlling cursor position in a textarea
By Stangeriffic02 in forum General Tech DiscussionReplies: 1Last Post: April 29th, 2005, 02:54 PM -
Mouse cursor moving on its own
By moab in forum Security and Privacy IssuesReplies: 3Last Post: October 6th, 2003, 03:36 PM
Rape is not indecent: it is a crime. The giving of flowers to a lady has symbolic and contextual significance that might be related to gender politics. The "pill" may have altered "gender...
Roman Polanski may be a...
