Results 1 to 9 of 9
    Jun 2006
    26
    DVD+-RW drive not working
    When I put a blank DVD-RW into my HL-DT-ST GCA-4164B, the drive will not recognize the blank dvd. Then when I put a blank dvd+r in there it will recognize the dvd, but then after burning something to the dvd it either doesn't read the burned dvd or it didn't write any data to it properly.
    I don't know what to do, I can't burn any DVD's with my DVDRW drive. But yet it reads commercial dvd's perfectly... It can create CD-R's and read CD's as well. Someone please help me.
    South Jersey
    11,368
    Ok, four things to check:
    1. Reload device drivers by deleting both the drive and IDE channel from device manager and reboot.
    2. Check the DMA setting in the IDE channel and make sure it's set to "UDMA-2" in "current transfer mode".
    3. Have you checked for a firmware update? Generally for OEM models, you should get this from the computer manufacturer's site.
    4. What is the system model?
    Jun 2006
    26
    My system model is a compaq presario sr1675cl. But I couldn't find the firmware updates for it
    Jun 2006
    26
    Ok I updated my firmware for my dvdrw drive and it is still not recognizing DVD-RW's when i put them in the drive. What is wrong with this POS
    South Jersey
    11,368
    How about the first two items I posted?
    Jun 2006
    26
    yup I did both of those and still no luck at all
    Ultimate Member Imperion1's Avatar
    Center of the U.S.
    2,031
    Jun 2006
    26
    Yup that's the exact same thing i used. I flashed my dvd drive and as far as I know the flash was successful. But still I can't burn dvd's
    Ultimate Member jrsweger's Avatar
    Oct 2004
    Upstate NY
    1,645
    What is the software that you are using to "burn" the DVD?
  1. vaio laptop CD/DVD drive not working
    By kidcollect in forum Technical Support
    Last Post: February 9th, 2009, 08:27 PM
  2. Laptop DVD drive not working
    By Hongfire in forum Technical Support
    Last Post: March 6th, 2007, 06:20 PM
  3. DVD Drive stopped working properly
    By duncan1984 in forum Technical Support
    Last Post: October 13th, 2006, 05:53 PM
  4. DVD drive not working properly.
    By benjaminha in forum Technical Support
    Last Post: January 21st, 2006, 08:26 AM
  5. help emachine dvd+/-rw drive not working properly
    By lisaanne in forum General Tech Discussion
    Last Post: August 21st, 2005, 12:55 AM
