Results 1 to 14 of 14
    Feb 2007
    Springfield
    13,484
    5
    System Build $400
    Hi all.
    I'm putting together a budget PC for a friend. He has $400 to work with, and a old HP that I can pull parts from also. Which really, the DVD drive is about the only thing I plan on using, since it's pretty old.
    But I threw together a list of parts, and I wanted some input on a couple things.
    First the parts list:
    Case:$19 + s/h
    Rosewell El Cheapo
    Mobo: $100 +s/h
    Biostar T-Force
    CPU: $82.99
    Intel E2160
    RAM: $52.99 + s/h
    Wintec AmpX
    PSU: From
    Antec 500 Basiq
    Now my main question is with the RAM. I've never used Wintec Brand before, and was curious if you guys had any experience with them.
    The system is mainly for WoW and internet browsing. I plan on using the onboard graphics and sound.
    Thanks in advance!
    FAQ's ~ Team Stats
    My PC
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,198
    4
    For WoW, even though it's hardly graphics intensive, I'd still go for a dedicated gpu.
    Feb 2007
    Springfield
    13,484
    5
    I'm still thinking about it. I just can't find one that would even be decent for WoW and still land $40 under budget.(amount for the PSU I'm selling him.)
    I'm open to suggestions though.
    FAQ's ~ Team Stats
    My PC
    Nov 2004
    Burning in Florida
    15,198
    4
    This isn't a good card by any stretch of the imagination, but it's got to be better than onboard. Plus (as i'm sure you know) it will take some load off the cpu.
    http://www.newegg.com/Product/Produc...82E16814121059
    It's about the best you can do for that price. It also "sports" 128bit vs 64bit of the really budget gpu's.
    Feb 2007
    Springfield
    13,484
    5
    I was looking at the IceQ version of that card before.
    I may see if I can fit that in budget
    FAQ's ~ Team Stats
    My PC
    Jan 2003
    Outside the box
    8,489
    4
    If you aren't planning on oc'ing, and your not going for anything else high end why not throw a lower end mobo in there and beef up the video card a bit more?
    Feb 2007
    Springfield
    13,484
    5
    Quote Originally Posted by RicheemxX View Post
    I was gonna try to get a little OC out of it. I've read numerous reports about how you can get those chips to 3.0Ghz on stock cooling. I was gonna check that out, and see what happend.
    My other thought of all this is maybe going for a x2 setup. I could maybe come out a little cheaper with the board and ram, and that would give me some more to work with on the gpu..
    EDIT:
    But I'm ordering parts weds, so I hopefully get them in Monday, which give me 3 1/2 days to build and install OS. So I got plenty of time..
    FAQ's ~ Team Stats
    My PC
    Feb 2007
    Springfield
    13,484
    5
    Is the 945GC chipset decent?
    I skipped that hole generation of chipsets..
    But I'm looking at this now..
    Motherboard: $53
    http://www.newegg.com/Product/Produc...82E16813128058
    CPU: $83
    http://www.newegg.com/Product/Produc...82E16819116036
    RAM: $49
    http://www.newegg.com/Product/Produc...82E16820145098
    GPU: $59
    http://www.newegg.com/Product/Produc...82E16814102084
    Case: $19
    http://www.newegg.com/Product/Produc...82E16811147073
    HDD: $48
    http://www.newegg.com/Product/Produc...82E16822148161
    PSU: $40
    Antec Basiq 500watt
    TOTAL- $302 without shipping
    $386.46 with shipping.
    I think I'm gonna try to spend the extra money on a little bit better of a case.
    What do you guys think?
    FAQ's ~ Team Stats
    My PC
    Dec 2005
    278
    http://www.newegg.com/Product/Produc...82E16811119068 - Get this case, FREE SHIPPING, and it will be about 5 bucks more since your case shipping is expensive.
    So the rest of the money can go to upgrades in other places.
    it will make all the difference... and you know that.
    Member drjekel_mrhyde's Avatar
    Nov 2005
    Chicago
    337
    MicroCenter
    They have a MB and AMD sempron bundle for 80ish and they work great for simple web browsing and burning DVD's
    http://microcenter.com/specials/cata...roadsheet.html
    Senior Member Foggy's Avatar
    CCC by the Sea
    857
    I don't think your shipping will be $84 if you order all at once.
    You can't get there from here
    Feb 2007
    Springfield
    13,484
    5
    Yeah, I'm hoping not...Thus why I like the Egg.
    As for the other replies, thanks for the help.
    Flyin, I may use that case instead, It seems like a better case all around.
    Jekyl, I'd feel really bad giving him and semperon. This should be able to last him for a couple of years. Being that he's just now moving up for a 1Ghz P3.
    Thanks all for the suggestions!
    FAQ's ~ Team Stats
    My PC
    Uncommon Man samwichse's Avatar
    State College, PA
    4,281
    If you're going budget, AMD is the way to go. Look at the AM2 4000+ Brisbane core. $66, a good overclocker, equivalent performance to the E2160 you're looking at.
    AM2 M/B with PCI express X16, 4 DDR2-800 slots, and nVidia 6100 onboard:
    http://www.newegg.com/Product/Produc...82E16813186105
    $40 AR
    You can go cheaper, but then you get only 2 RAM slots, which isn't worth it to me. But the price differences get you $30 more for the video card, which is your real limitation for gaming anyway.
    Sam
    Feb 2007
    Springfield
    13,484
    5
    The reason why I picked out the 2160, is it can OC to 3.0Ghz STABLE on stock. I've read about 100 reviews saying this. So if I factor in the OC, then it'll blow anything AMD out of the water at the pricing point. But I am making a list of AMD parts also to email to him. See what he thinks about the options. I'm trying to get a little stronger of a GPU for him, but I am trying to talk him into upping his budget another $50 or so. That would make it easy on me almost, and give him a pretty nice performer for the money.
    Have you used any Foxconn Mobo's before?
    I personally haven't, but have heard that their not the best name brand out. If it's gonna be a solid runner, then I'll pick that up. But again my experience is swaying me towards Gigabyte or ASUS.
    FAQ's ~ Team Stats
    My PC
  1. new Gforce 2 MX 400 locks up my system
    By pbharris in forum Graphics Cards and Displays
    Last Post: January 5th, 2002, 12:34 PM
