32-Bit Vs. 64-Bit
Currently Active Users: 1579
Discussions: 200,955, Posts: 2,379,493, Members: 246,327
Old January 11th, 2008, 03:14 AM   Digg it!   #1 (permalink)
Exclamation
32-Bit Vs. 64-Bit
Hi.
Is Merlin U630 a 32/64 -bit data-card?
How do I know how many bits on a specific PCI slot?
Can 32-bit work with 64-bit, and how about vice-versa?
I really need urgent answers, thanks.
I learnt from the best. YOU are amongst them!
Last edited by LetMeKnow : January 11th, 2008 at 03:39 AM. Reason: The PCI To PCMCIA Adapter I'm using is a 32-Bit...
LetMeKnow is offline   Reply With Quote
Old January 11th, 2008, 04:47 AM     #2 (permalink)
PC Upgrade Procrastinator
ShyguyXPC's Avatar
why do you need to know about PCI slot, from what I can tell doing a quick Google search the card is a PCMCIA / Type II PC Card...
http://www.novatelwireless.com/produ...rlin-u630.html
Old January 11th, 2008, 01:48 PM     #3 (permalink)
THE Gimp Clown Fish!
nemowolf's Avatar
Lol, i think they may be refering to the question of will it work with a 32bit or 64bit OS maybe?
Old January 11th, 2008, 08:13 PM     #4 (permalink)
Post
Because everytime a connection TO my Merlin U630 is being established,
upon getting the good blue LED lamp, I'll end up with the dreaded blue screen,
which part of what it says is: "NMI: Parity Check / Memory Parity Error"...
I know it's a Type II card (and I've been to that URL several times before),
but is it 32/64 -bit?
And I use that data-card with my desktop PC, with the help of
a PCI-based PCMCIA Adapter (RICOH chipset, it says).
I suspect the PCI slot where the adapter is put might be incompatible
with either that very adapter or Merlin U630...
or Windows 2000 since although this OS is supported,
I'm actually using it on a desktop PC...
I'm not simply Vs.-ing, thanks.
Old January 11th, 2008, 08:27 PM     #5 (permalink)
nemowolf's Avatar
there is no reason to be asking if its 32bit or 64 bit. You need to find out if your laptop supports Type II PCMCIA card.
So lets start with your laptop model and manufacturer. If your getting an error you may not be using a card that your laptop supports or something is wrong with your laptop.
Old January 11th, 2008, 08:31 PM     #6 (permalink)
I said I use it on my DESKTOP PC.
Old January 11th, 2008, 08:45 PM     #7 (permalink)
Prince Lalijama's Avatar
Send a message via MSN to Prince Lalijama
I'm assuming you have a PCMCIA to PCI adapter, also windows 2000 isn't very good OS IMO. But that isn't the issue.
Try switching out PCI slots with the adapter, did it always have this problem.
I think its either the card or the adapter.
But this could have nothing to do with the card and could be something wrong with the system.
I don't know, why am I trying to help?
I'm PL, I've come to suck all the intelligence out of this thread.
Prince Lalijama is offline   Reply With Quote
Old January 11th, 2008, 08:54 PM     #8 (permalink)
nemowolf's Avatar
Well its hard to understand what your trying to say...
Here is the thing, ALL your PCI slots are EXACTLY the same baring PCI-E. Switch the PCI and i can almost be 100% sure your going to have the same problem. The thing is that Adapters are not a guarantee of functionality.
Since your getting memory errors, this card probably doesnt work with your adapter. Try another adapter or try using a different card in the adapter to test it out. Do you have the model number for the adapter as it may not support Type II PCMCIA cards?!
Old January 11th, 2008, 10:58 PM     #9 (permalink)
Send a message via AIM to RamonGTP Send a message via MSN to RamonGTP Send a message via Yahoo to RamonGTP
I wouldn't come to that conclusion so hastily. Changing the PCI slot may assign the device a different IRQ which MAY fix the problem. You may very well be correct, but in my experience, it's worth a try and the failure rate has not been 100%
RamonGTP is offline   Reply With Quote
Old January 11th, 2008, 11:21 PM     #10 (permalink)
Lightbulb
- yes I got one.
- will try sooner.
- me too, but it's not easy to determine. For me.
- you sure nothing to do?
- but I'm now blaming Win. 2000 though,
- i don't know either, but thanks!
- i wouldn't buy if it doesn't support such cards.
- and this is the adapter, although I bought it from somewhere else.
- same like Prince Lalijama said, I believe. Thanks!
HELP !! A bit worried !! 8800GTX SimD1978 Graphics Cards and Displays 7 January 8th, 2008 08:05 PM
Is It Just Me? (2947)
Print spooler problem (15)
Open With ..... Win7 (1)
Kingston Bluetooth Dongle Driver (0)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
