Results 1 to 6 of 6
    Realplayer..no sound?!?
    I have the new realplayer download and i can't seem to get any audio out of it..i can't hear anything! i can see things just fine. i played around in preferences with the soundcard option and changing my internet speeds but nothing has worked. my soundcard is fine cuz it plays everywhere else just fine except this program. Does anyone know what might be wrong?
    ch1221
    Nov 2008
    same issue here, any solution? thanks
    Feb 2008
    1,671
    Welcome to the site.....
    Please check and make sure you dont have it MUTED.....
    You might wanna try this version of realplayer (No ads,no garbage (This is a customized version 10))
    I use RP8 and i love it..... (Anything after 8 is crap in my opinion (AOL joined the team and ruined it (IMO))
    Good luck!
    Sep 2009
    Alazmy
    Uninstall sound card driver then restart to enable windows to reinstall it again
    but make sure you have the driver either in the system as recovery files or as a cd.
    Dec 2008
    East Chamunga
    2,364
    What file extensions did you set as default in RP? I only use it to play .rm files, so no other files will open in it...
    ◄ it is what it is ►
    Feb 2008
    1,671
    Quote Originally Posted by Dude111
    I have since tried this version AND IT IS OVER BLOATED CRAP LIKE ALL THE NEW REALPLAYER VERSIONS!!
    Realplayer died after Version 8 due to AOL trashing the product!!
    Welcome to the site iseekeen
  1. RealPlayer....alternatives?
    By yclyde in forum Applications and Operating Systems
    Last Post: July 22nd, 2005, 09:54 PM
  2. HELP with RealPlayer
    By brotherleelove in forum PC Hardware
    Last Post: July 6th, 2005, 12:37 AM
  3. Anybody have RealPlayer 8?
    By Redwolf in forum IMO Community
    Last Post: June 13th, 2002, 02:18 PM
  4. Realplayer under linux
    By SpookyEddy in forum Applications and Operating Systems
    Last Post: December 12th, 2001, 06:31 PM
