Results 1 to 15 of 15
    Mobile Member ShuckyD's Avatar
    Apr 2005
    S. Central PA
    3,646
    Which PSU in the 500W range?
    I now need a new PSU for my computer, i went into my room this morning and pushed the button and the damn thing snap, crackled, and popped.... ohh and stunk as well
    So here are my choices that I have found on NewEgg.. I am looking in the $50-60ish range for a decent PSU, the one I am replacing is a Logisys 550W PSU, which sorta sucked, but worked for years. You can see what my computer has in my sig, add a few fans and you'll get the idea Which PSU would you get below? Also post if you know another one that should take a look at.
    Thanks,
    ShuckyD
    Thermaltake - http://www.newegg.com/Product/Produc...82E16817153052
    CoolerMaster - http://www.newegg.com/Product/Produc...82E16817171016
    CoolerMaster #2 - http://www.newegg.com/Product/Produc...82E16817171018
    RaidMax - http://www.newegg.com/Product/Produc...82E16817152029
    Mobile: Thinkpad T61 | WinXP Pro | C2D T8300 CPU | 3GB DDR2 | 320GB Hybrid SSD HDD | AGN & WWAN
    Desktop: Dell XPS 8300 | 3.4 Ghz Intel i7 | 8GB DDR3 | 1TB OS, 1.5TB Mirrored DATA
    Feb 2007
    Springfield
    13,484
    5
    Hi there Shucky!
    To be honest, I really don't like any of the one's you posted. But if I had to decide out of those, I'd probably take the Thermaltake.
    My choices in that price range would be:
    http://www.newegg.com/Product/Produc...82E16817189013
    http://www.newegg.com/Product/Produc...82E16817371004
    http://www.newegg.com/Product/Produc...82E16817189014
    http://www.newegg.com/Product/Produc...82E16817341012
    ^ The one I'd opt for myself. OCZ is a good brand!
    http://www.newegg.com/Product/Produc...82E16817256037
    ^My second choice.
    Hope I helped!
    FAQ's ~ Team Stats
    My PC
    Healdsburg, CA
    13,321
    Out of the one's ShuckyD selected, I like the COOLER MASTER eXtreme RP-500. I've always had good luck with the Cooler Master PSUs.
    But from Karma's list, the SILVERSTONE ST50F is the best of the bunch followed closely by the OCZ.
    Jan 2003
    Outside the box
    8,489
    4
    The coolermaster extremes aren't bad mine seems to be a bit noisy but IMO I wouldn't buy one at that price. These things go on-sale for around $10+shipping after MIR almost every week. Microcenter has them right now 9.99 after $30mir http://www.microcenter.com/single_pr...uct_id=0258432
    Apr 2005
    S. Central PA
    3,646
    is the brand Xclio good? I see a couple linked above and sorta liked it.. I also liked that ThermalTake I picked, but If i can find something around that price with "free shipping" i'll go for that.
    Feb 2007
    Springfield
    13,484
    5
    X-Clio's are a good brand. If I remember correctly their a division of Silverstone.
    They're in JP's sticky for PSU's under the *Good* catagory. I just used one for a build for a friend, and it even pushes a decent sized GPU also. (ATI 3850 what I used)
    FAQ's ~ Team Stats
    My PC
    Apr 2005
    S. Central PA
    3,646
    I really like that one in the link that RicheemxX posted and come to think of it I will within a few miles of a MicroCenter today, not sure if they will be open, but I can always call.
    Can anyone else vouch for that one?
    Feb 2007
    Springfield
    13,484
    5
    The only thing I don't like about that unit,
    1. Only has 16amp 12v+ rails. Where most of the others are more then that.
    2. It's only 70% efficient. Where as most of the other one's I recommended are 80%.
    Other then that, it looks ok to me..
    FAQ's ~ Team Stats
    My PC
    Healdsburg, CA
    13,321
    Being that he's running an 8600GT that requires at least a 350W PSU w/ 22A on the 12V rail, that PSU will be fine.
    Oct 2003
    Canada [Maritimes]
    1,260
    http://www.newegg.com/Product/Produc...82E16817341010
    a little more expensive but well worth the money
    i have one install and is very quiet and use less power than you
    would think
    running a BFG 8800 gt with this PS
    read up on it
    http://www.hardwaresecrets.com/article/451
    if you scroll down you will find its manufacture by FSB
    Feb 2007
    Springfield
    13,484
    5
    read up on it
    if you scroll down you will find its manufacture by FSP
    That's the same PSU I have!
    FAQ's ~ Team Stats
    My PC
    Jan 2003
    Milwaukee, WI
    7,657
    http://www.newegg.com/Product/Produc...82E16817256039
    This is by far the best bang for buck in that price range
    Apr 2005
    S. Central PA
    3,646
    Thanks all for the reccommendations... I ordered the one from MicroCenter yesterday and I like the one that JPMiller posted but it is only 400W, I may just order that one as well and send both rebates out together if that last one posted is that much better than the CoolerMaster I just bought.. ($9.99 + shipping AR)
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,198
    4
    Watts mean little compared to amps....400w is still plenty for most systems minus high end SLI usage...
    Also, that little 400w puts out more amps than that "500w" coolermaster you order, and so does my fsp400w...I've got a feeling the coolermaster is truly 350-400w but disguised as 500w, especially at that price.
  15. #15
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,560
    Quote Originally Posted by SoloCamo View Post
    i agree, the FSP is the best for the price.
    Not to mention I own it, and I love it.
  1. mid range PSU tests
    By JPMiller in forum General Tech Discussion
    Last Post: May 24th, 2007, 06:38 PM
  2. Cooler Master eXtreme 500w PSU - hope it's good...
    By ArcticFox in forum General Tech Discussion
    Last Post: January 10th, 2007, 01:38 AM
  3. DOA PSU (EZcool 500W)
    By trublubiker in forum General Tech Discussion
    Last Post: October 13th, 2006, 05:34 AM
  4. what 500w+ psu?
    By Micky758 in forum Processors, Memory, and Overclocking
    Last Post: April 1st, 2005, 01:16 PM
  5. 500w PSU...questions?
    By Sweeper in forum General Tech Discussion
    Last Post: April 20th, 2002, 12:49 PM
