Results 1 to 5 of 5
    C:\Documents and Settings\user\Local Settings\Temp
    Hey all
    I am running out of space on my c: drive and when looking through what dirs where taking up space I found this out C:\Documents and Settings\user\Local Settings\Temp. It had about 3gb of files in it. Is it safe to delete this dir? I couldn't tell what it was used for? I am running XP.
    Thanks,
    Jutah
    Smile. It's easy. :) paul9's Avatar
    Aug 2003
    Gateshead U.K.
    14,160
    Reboot your PC then delete everything in the temp folder. Anything in use will not delete, so try again with other files until you get rid of most of them. Perfectly safe to delete, as it only contains temporary files, which really should be cleaned up by the applications which left them there in the first place.
    San Diego, CA
    6,398
    If you're running out of space, freeing up 3GB is but a temporary fix. You will want to upgrade the drive soon. But to answer your question, yes, it is safe to delete the temp folder.
    nice thanks guys
    Jutah
    Ultimate Member BluesMan1's Avatar
    Jun 2003
    Not on this planet..
    1,101
    Use this:http://www.ccleaner.com/
    CCleaner is a nice little program that will take care of your Temp files for you, easy and fast.
  1. User folder completely locked in Documents and Settings
    By ingiemmm in forum Technical Support
    Last Post: January 23rd, 2007, 09:20 PM
  2. Can you use the same documents and settings folder on two computers?
    By Sammy_The_Snake in forum Technical Support
    Last Post: January 12th, 2007, 01:32 PM
  3. Moving location of documents and settings
    By ken_shoti in forum Applications and Operating Systems
    Last Post: December 27th, 2005, 10:16 AM
  4. Help Can't access Documents And Settings
    By filipino in forum Technical Support
    Last Post: October 24th, 2005, 06:21 AM
  5. Changing the name of a Directory in 'Documents and Settings'...
    By matius in forum Applications and Operating Systems
    Last Post: April 29th, 2004, 10:40 PM
