Join TechIMO for Free!
Thread Tools
Currently Active Users: 3051
Discussions: 186,619, Posts: 2,227,168, Members: 230,251
Old April 15th, 2008, 02:58 PM     #11 (permalink)
buckaro's Avatar
Not sure about the best site, but ebuyer seems cheapest.
Also a suggestion for a case and PSU, the antec sonata III (link). It about the only case and CPU combo which is any good.
buckaro is offline   Reply With Quote
Old April 15th, 2008, 03:52 PM     #12 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
Originally Posted by buckaro View Post
The X850xt is about 3-4 years old now, and i believe the 9600GT would significantly improve graphics performance overall. That said it depends on what games your playing (any examples?), otherwise sticking with the x850Xt for now and upgrading later could do the trick.
The x850xt was a great card for it's time, and even on todays games it can still pump out medium settings on average. However, it only has SM2.0 and that severely limits it's usage on some games, in fact some games won't even run on the card.
I used to run an x800pro and to overcome the lack of sm3.0 support I just picked up a x1950pro which is roughly 10fps faster on average than my old x800pro (which I had at the performance of an x800xtpe btw) and it runs all my games on high settings for the most part. (crysis need not apply)
SoloCamo is offline   Reply With Quote
Old April 15th, 2008, 04:37 PM     #13 (permalink)
It all depends on how much you want this pc to do. You can get an older card that will let you game, though possibly not games not out yet.
If you want to use DirectX10, you will have to get Vista. I personally suggest getting vista for a gaming pc. The big bugs have been worked out. You might have a problem if you use an old printer, or something like that, but otherwise you will be fine. Don't forget that this also requires a DX10 card.
I believe quad-cores are superior for video and picture editing (correct me if wrong), but for gaming, the benefit is greatly diminished.
johnross2007 is offline   Reply With Quote
Old April 15th, 2008, 06:46 PM     #14 (permalink)
Folding@home since 1862!
KarmaKiller's Avatar
Well, your right. Most of the time dual cores do perform better in some games. But, if the game is multi core threaded, then the Quad makes a big difference. Not only that, but it's very very future proof too. When all the games and apps start coming out that are mutli core threaded (which that's more and more everyday) then you'll be happy you stuck to the Quad.
Also, something else to think about. Let's say a game you play is only dual core threaded, then it'll just run on 2/4 cores, leaving you with 2 cores for AV, Music, etc.
Intels Quads are made up of 2x dual core chips, so your not gonna be missing out on any FPS or anything like that. If your building a new system, you might as well get a quad.
Just IMO of course..
EDIT:
A side note. Intel 65nm cores are 30% faster clock for clock then AMD's. Now Intels 45nm cores are 20% faster then their 65nm cores. So Intels are the faster chip right now...
MainRig: Q6600@4Ghz |EVGA 780i |EVGA 9800GX2 |4Gigs Tracers|
|WD640Gb | OCZ 600w |ApogeeGT- LaingD5- Black Ice 240mm
Folding FAQ's-Fold for Team 111-Stats
Old April 16th, 2008, 07:47 PM     #15 (permalink)
Send a message via MSN to geddes-i
Ok well i might stick with my x850xt just now to save some money and buy a nvidia 9600gt or something like at later on. I mean i can play newish games using just my current computer and a radeon 9600 so surely the x850xt cant be 2 bad. Ok so should i get vista ultimate 32 bit or 64 bit, or just get home premium ?
And should i definitely get quad core ? I will mainly be gaming as i say so...
And yea ebuyer does seem cheap for parts so stick with that just now i think.
Oh and also can anyone recommend a good case thats light and enough room for hardware of today to fit inside ? im not too bothered about looks to be honest but something light with lots of room inside would be great. Colours such as piano black would be nice.
Thanks for all your help !
geddes-i is offline   Reply With Quote
Old April 16th, 2008, 07:58 PM     #16 (permalink)
Well, on the Vista question. It depends on what all you plan on installing in your system. If you plan on having 4 gigs or RAM, or more, then you'll need 64 bit Vista.
If you plan on sticking under 4gigs of RAM, then 32 bit will do the trick. As far as Ultimate or Home, that's up to you. In all honesty, I don't know all the differences, so I'll leave that up to someone else here.
About the Quad, again, that's up to you. If it were me, I'd get a Quad to future proof, like I said earlier. But depending on your budget, and how much $ you drop on other components, you may not have enough left.
Old April 17th, 2008, 09:49 AM     #17 (permalink)
ok
can anyone throw together a list using:
32 bit vista home premium
2 gigs ram
dual core processor of some sort preferably a good one
a trustworthy psu with a good wattage
a good motherboard capable for pci expressx16. a good board thats great for games if there is.
and a hard drive say with 200Gb or more room
and a decent case, not so bothered bout the looks but black is nice and with good ventilation.
as for the gpu i will stick with my x850xt to cut down on the costs but i will upgrade at a later date
cheers again
Iain
Old April 17th, 2008, 12:45 PM     #18 (permalink)
pullmyfoot's Avatar
oops
5200+X2 @ 3.12Ghz | AC Freezer Pro | Gigabyte 790GX | 2 gigs OCZ Reper | Saphire HD4850 @ 700Mhz/1045Mhz | 22" Samsung
3600+X2 @ 2.6Ghz | Gigabyte 570i | XFX 7600GT SLI
pullmyfoot is offline   Reply With Quote
Old April 17th, 2008, 05:43 PM     #19 (permalink)
?? oops ?
Old April 18th, 2008, 05:14 AM     #20 (permalink)
pullmyfoot's Avatar
i posted by accident. well anyway ok since i did lemme make you a nice list
CPU (120) - http://www.dabs.com/productview.aspx...520,4294952945
Ram (40) - http://www.dabs.com/productview.aspx...239,4294959063
Mobo (60) - http://www.dabs.com/productview.aspx...50000,12,50509
PSU (33) - http://www.dabs.com/productview.aspx...ey=11259,50121
GFX (116) - http://www.dabs.com/ProductView.aspx...0000&InMerch=1
HD (53) - http://www.dabs.com/productview.aspx...60000,42240000
i like this case but its really up to you man. case is all personal preferance
http://www.dabs.com/productview.aspx...42080000,50915
all that is 400+. then get the OS with the remaining money
for a little more you can get an 8800GT instead of a 9600GT which is faster in games
http://www.dabs.com/productview.aspx...50544,48070000
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Help building a computer? FlyinHawaiian General Tech Discussion 10 December 21st, 2005 04:53 PM
Building a new computer -Sinister- General Tech Discussion 7 August 23rd, 2005 09:41 PM
help building a new computer hollaback04 General Tech Discussion 7 October 21st, 2004 07:51 PM
HELP in building a new COMPUTER natbeys General Discussion and Buyer Guidance 26 February 20th, 2004 10:56 PM
Building a computer postalone Motherboards 10 December 26th, 2003 08:59 AM
Is It Just Me? (556)
Transfering balances from one credi.. (6)
Misery Loves Company... (1854)
Linksys WRT54G (5)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (15)
1 internet. 1 house. 3 computer. ho.. (14)
Help with broken bracket from A.. (3)
RAID 0 External Drive Slow/Fail.. (2)
Switching HDDs (1)
new kid (0)
Benefits of having two separate.. (1)
Laptop doesn't stay connected t.. (10)
Hard Core Overclock (14)
1 internet. 1 house. 3 computer.. (14)
Word, Excel, Firefox, IE7, etc... (0)
