Join TechIMO for Free!
Thread Tools
Currently Active Users: 3050
Discussions: 186,620, Posts: 2,227,170, Members: 230,251
Old April 23rd, 2008, 05:12 PM     #31 (permalink)
Send a message via MSN to geddes-i
Originally Posted by Big_Daddy View Post
Yes, you should be able to add the hard drive.
yes but if the hard drive comes form a pc running windows xp and goes to a pc with vista will it still work or does that not matter ?
cheers
geddes-i is offline   Reply With Quote
Old April 23rd, 2008, 05:48 PM     #32 (permalink)
yes. Think of it as a large flash drive.... that you have to install. tbh, when I pulled data off my old HDD, I didn't even put it in the case. I had it sitting on a platform next to the case. Even if it has an OS on it, it won't be used. Also, I beleive my old HDD was in FAT32, and my vista is the one kind (forget the name). It still is not a problem.
johnross2007 is offline   Reply With Quote
Old April 24th, 2008, 10:34 AM     #33 (permalink)
buckaro's Avatar
The build i suggested is perfectly fine, but i've added the antec sonata III, which is a great case and PSU and saves any hastle looking for a PSU, plus changed the OS to 64bit, but unless you will upgrade to 4gb of memory (including the GPU) or more then the 32bit version is the same speed and £10 cheaper (link in my other list).
Intel Core 2 Duo E8400 OEM £132
OCZ 2GB PC6400 PLATINUM XTC £30
MSI P35 Neo-F £55
Seagate Barracuda 250GB £37
Optiarc DVD-RW SATA £17
Artic cooling 7 HSF £15
Windows Vista premium edition £72
Antec Sonata III case w/ 500W earth watts PSU case £75
Total £433
buckaro is offline   Reply With Quote
Old April 26th, 2008, 11:45 AM     #34 (permalink)
qrs321's Avatar
Send a message via AIM to qrs321
If you plan on not doing a lot of media editing, and just plan on playing games and simple stuff. Then i recommend vista basic. It gives you access to DX 10 but also needs less power because it isn't as beautiful as premium or ultimate
qrs321 is offline   Reply With Quote
Old April 28th, 2008, 08:01 PM     #35 (permalink)
I would certainly not go basic. The aero on premium and up can be turned off manually.... and I personally just think its pretty . I leave aero on as it really doesn't affect performance to a noticable degree, at least for me. Some people can be picky though, it just depends. Either way, you get more features than just Aero with premium.
Old April 28th, 2008, 09:45 PM     #36 (permalink)
qrs321's Avatar
Windows basic
Remember thought that this is a budget computer and with a $500 (euros?) either way...the $30 difference between basic and premium can be the difference between a 9600gt and an 8800gt. And if your making a budget computer you're going to have to make some sacrifices to put the money where it really matters(cpu, gpu, ram, etc.)
About features: thats why i said if you're only doing simple stuff and gaming. Personally i don't make lots of videos etc. and use the many features of windows, i have a mac for productivity things.
Old May 16th, 2008, 08:49 PM     #37 (permalink)
ok so does anyone have a finalised list i could use as im still not too sure what processor to go for and whether it be an intel or amd. Remember this pc woul;d be getting used to play games such as crysis, flight sim x in high detail.
Cheers everyone
Old May 16th, 2008, 09:04 PM     #38 (permalink)
Folding@home since 1862!
KarmaKiller's Avatar
I can make a list real quick. Hold on a sec and I'll post it.
Ok, here it is.
Case: £21.99inc vat
http://www.ebuyer.com/product/134798
Motherboard: £59.38inc vat
http://www.ebuyer.com/product/125082
CPU: £136.95inc vat
http://www.ebuyer.com/product/131823
GPU x2 : £79.99inc vat
http://www.ebuyer.com/product/144336
RAM: £29.99inc vat
http://www.ebuyer.com/product/116755
HDD: £32.99inc vat
http://www.ebuyer.com/product/131300
PSU: £39.71inc vat
http://www.ebuyer.com/product/112899
DVD burner: £15.98inc vat
http://www.ebuyer.com/product/129527
Grand total comes to : £498 without shipping.
And that give you a Quad core SLI rig with 2gigs or RAM. I believe this would max out every game your throw at it, including Crysis.
(I'm kind of impressed I hit that under 500... )
Edit:
The CPU doesn't come with a cooler though. So when you add that in you go over 500.
You can swap out the SLI for a 8800GT and still run games close to high settings.
MainRig: Q6600@4Ghz |EVGA 780i |EVGA 9800GX2 |4Gigs Tracers|
|WD640Gb | OCZ 600w |ApogeeGT- LaingD5- Black Ice 240mm
Folding FAQ's-Fold for Team 111-Stats
Old May 16th, 2008, 09:31 PM     #39 (permalink)
Gigabyte P35 DS3R £64
Intel E8200 £112
Corsair 2x1gb DDR2 1066 £53 (I have been held back from further o'cing because of slower ram)
HD 640gb SATA 66
Samsung 20x DVDRW £16 (£32 if you want 2)
AC Freezer 7 Pro £15
Vista Home Prem 64bit £63
8800gt 512mb £102
OCZ stealth 500w £36
=£526
+case (Picking a case I find is a personal thing).
Gigabyte P35 DS3L, Intel E6550 @3.25ghz
4gb DDR2 1066, EVGA 8800GT 512mb,
Cool Master RC-690, WD Raptor 150gb, WD 500gb and 250gb AAKS
thephilosophizer is offline   Reply With Quote
Old May 17th, 2008, 09:44 AM     #40 (permalink)
karmakiller thats a great list
but should i go quad core or dual core as i have heard dual core works better for gaming
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Help building a computer? FlyinHawaiian General Tech Discussion 10 December 21st, 2005 04:53 PM
Building a new computer -Sinister- General Tech Discussion 7 August 23rd, 2005 09:41 PM
help building a new computer hollaback04 General Tech Discussion 7 October 21st, 2004 07:51 PM
HELP in building a new COMPUTER natbeys General Discussion and Buyer Guidance 26 February 20th, 2004 10:56 PM
Building a computer postalone Motherboards 10 December 26th, 2003 08:59 AM
Is It Just Me? (557)
Transfering balances from one credi.. (6)
Misery Loves Company... (1854)
Linksys WRT54G (5)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (15)
1 internet. 1 house. 3 computer. ho.. (14)
is there a way to Grep for a sp.. (0)
Painfully Slow eSata External 1.. (0)
Help with broken bracket from A.. (3)
RAID 0 External Drive Slow/Fail.. (2)
Switching HDDs (1)
new kid (0)
Benefits of having two separate.. (1)
Laptop doesn't stay connected t.. (10)
Hard Core Overclock (14)
