Building myself a new system
Currently Active Users: 1792
Discussions: 200,909, Posts: 2,378,940, Members: 246,276
Old April 14th, 2008, 12:24 PM   Digg it!   #1 (permalink)
Fossil
Theophylact's Avatar
Well, just after I got my taxes printed out, my computer (an Athlon 2500+) died the ugly death.
I can't say I'm surprised; this is the one I had such problems with a year ago. I think at the very least one of the IDE controllers was banjaxed; even after the repair installation, everything ran slowly, and I could never attach a second drive to the IDE cable.
So I'm building a new one. Unfortunately the new motherboard has only two PCI slots. One will have to go for my SCSI card (until I spring for a new scanner), and the other for my dialup modem (because I have a really flaky DSL connection). That means my TV tuner card goes back into its box (perhaps I can use it in the Ubuntu machine), as does the adapter for a card reader (though I can probably get a new internal one that runs off a USB header).
I'm not going high-end on the processor; I'm getting the Athlon 64 X2 5000+ Brisbane black box 65W, which should handle any work I'm likely to do. And I'm only getting 2GB of DDR2 800 RAM, because (1) the processor isn't that fast, (2) I'm not overclocking, and (3) I'm going to be running Win XP. I went for only a 320 GB SATA HDD because I have a 500 GB external as backup. If things get really cheap later on, my Antec Sonata case has room for 4 hard drives, and the motherboard has 5 SATA connections; right now, I'll be using the single IDE controller for my DVD burner and my Zip250 drive. I have bought a new power supply, partly because the one in the Sonata doesn't have SATA connectors (though adapters are really cheap), partly because I'm not sure it had a 24-pin power connector (the current board is a 20-pin one), and partly for future needs (if I'm ever crazy enough to buy a high-end processor and graphics card).
Anything I should know about, or change?
A man is not free if he cannot see where he is going, even if he has a gun to help him get there. -- A.J. Liebling
Theophylact is offline   Reply With Quote
Old April 14th, 2008, 12:39 PM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Hmm.. You picked out a nice motherboard. So no complaints from me on that.
Of course, I always think people need a faster CPU, but your a smart guy, and if that's all you'll need, then I'll leave you alone on that.
Honestly it looks like a solid build. I really don't see a need to swap out any of the parts you have picked out.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old April 14th, 2008, 01:04 PM     #3 (permalink)
Purple People Eater
nickslick74's Avatar
Looks good Theo!
Cerca Trova - Seek and ye shall find
nickslick74 is offline   Reply With Quote
Old April 17th, 2008, 06:08 PM     #4 (permalink)
Fossil
Made one minor miscalculation: The Athlon 64X2 5000+ comes without a heatsink/fan. Any recommendations for a reliable, relatively quiet, not exorbitantly expensive HSF? As I said, I'm not overclocking this baby.
Old April 17th, 2008, 06:14 PM     #5 (permalink)
\m/(°-°)\m/
http://www.newegg.com/Product/Produc...82E16835103031
It works good, is almost silent, and the best part, it's cheap!
Old April 17th, 2008, 08:12 PM     #6 (permalink)
Training for Bankai
JPMiller's Avatar
I suggest THIS PSU instead...
It has higher rails, and is much cheaper even without rebate
With the $15 you save, you can opt for a full ATX board with enough PCI slots to use your TV Tuner
And I'd spend the other $5 for a 2 year longer warranty, and better speeds from a Seagate 320...
Old April 17th, 2008, 09:09 PM     #7 (permalink)
分かりますか。
carl33p's Avatar
Send a message via AIM to carl33p
2 more dollars for the regular x2 5000+ with the stock HSF.
You proly are aware, 2GB Ram can be found 35$ if you dont want to deal with the rebate.
Get a different PSU. That one is way to expensive! IMO, Antec's failure rate is reason enough to stay away even if it costed half as much.
carl33p is offline   Reply With Quote
Old April 18th, 2008, 09:42 AM     #8 (permalink)
Fossil
Well, I've already received all the parts I mentioned above, so the only real issue is the HSF, though I'm probably going to get an SATA DVD burner to free up one of the IDE connections for the old HDD. I am thinking about one of these two HSFs; the comments on KarmaKiller's recommendation indicate that it's hard to install without damaging the board.
Old April 18th, 2008, 06:04 PM     #9 (permalink)
\m/(°-°)\m/
Hi Theo.
Just some FYI, the coolermaster units are not hard at all to install. I've personally put 2 of these in systems I've built for friends, and I've never had a problem.
They have 4 push pins, line them up with the holes, and push down. It even comes with thermal paste on the HSF itself.
I'm not sure what the Newegg reviews are talking about. If there was a chance that you might break your board upon install, then I highly doubt they'd even release the product.
I just thought I'd add a little more info for ya!
But I have to say, the Arctic Freezer model you linked to looks good as well. I run a Arctic Freezer in my current system, and love it! It keeps the CPU nice and cool, and is near silent also.
Old April 18th, 2008, 07:55 PM     #10 (permalink)
Fossil
Originally Posted by KarmaKiller View Post
Hi Theo.
I think it was a bit of misreading on my part. The Coolermaster was for an Intel board, which has a 4-pushpin mount. I wound up buying the Arctic Cooling Alpine 64, which fits the AM2 socket.
building new system Mombo323 Storage Related 9 April 15th, 2006 10:42 AM
Building a system, help please. joeyhause General Tech Discussion 9 September 21st, 2004 06:37 PM
Building a new system! jerrygarcia General Tech Discussion 10 February 17th, 2003 04:24 AM
Building a new system. <help me> XT General Tech Discussion 6 June 19th, 2002 04:44 AM
building a second system ryogenetic General Tech Discussion 10 December 30th, 2001 02:53 PM
Why is Khalid Sheikh Mohammed even .. (5)
Is It Just Me? (2817)
HIS HD5770 graphic card question (14)
Foreign voltage (7)
Print spooler problem (7)
EVGA 9800 gtx help with finding a g.. (7)
Foreign voltage (7)
Asus P4G8X Mobo (3)
windows vista security holes (2)
World's largest Monopoly Game using G.. (329)
EVGA 9800 gtx help with finding a goo.. (7)
Need hard disk drivers (4)
Boot Problem? (0)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
hybernate option (2)
