April 24th, 2008, 04:45 PM #1
Problems with USB Mass Storage...
I have my sidekick and when i use the usb connection my light on the phone turns on but the computer doesnt recongnize it at all.
It was working perfectly few days ago.
Ive went under device manager and it doesnt even show under that.
Help please..
-Mike
April 24th, 2008, 06:35 PM #2Ultimate Member
- Jun 2002
- 1,477
Was it plug and play (native xp/vista driver)?
If not try reinstalling the software or obviously a different usb plug and/or cable.
April 25th, 2008, 10:26 AM #3
If this is a laptop, unplug the power and remove the battery for a few seconds.
MCSE, MCP and nut job
April 26th, 2008, 04:28 AM #4
It is a plug and play and im using Vista.
I will try to unplug it and detach the battery and tell you the outcome...
USB Mass storage emulation software?
By otheos in forum Applications and Operating SystemsReplies: 1Last Post: February 12th, 2007, 09:19 PM -
USB Mass storage issue (yes another one)
By about_that in forum Technical SupportReplies: 1Last Post: September 26th, 2006, 12:09 PM -
Sony USB Mass Storage Device worked awesome couple days ago, now doesnt?
By _Switch_ in forum Storage RelatedReplies: 2Last Post: September 18th, 2005, 09:42 PM -
USB Mass Storage Drive, need help
By The_Pink_Rabbit in forum Storage RelatedReplies: 2Last Post: December 6th, 2003, 01:22 AM -
usb mass storage==scsi device
By samwichse in forum Linux and UnixReplies: 4Last Post: November 19th, 2003, 10:48 AM
found the drive and it is listed as unallocated space. i'm just wondering if it sees my dual boot linux partition.
How do i delete a partition that i...
