Join TechIMO for Free!
Thread Tools
Currently Active Users: 3012
Discussions: 186,621, Posts: 2,227,176, Members: 230,251
Old May 8th, 2008, 05:21 AM   Digg it!   #1 (permalink)
I am NOT MAD!!! only CONFUSED!!!
Cables with tags from ECS Motherboard (which is now faulty/broke)
Tag 2+D Green cable
Tag 1-D White cable
Tag 1+D Blue cable
Tag 2-D Yellow cable
Tag 1+5v Red cable
Tag 1Ground Black cable
Tag 2Ground Black cable
Tag 2+5v Red cable
Please advise which cables go where on replacement M7211 motherboard
Base blocks which the pins are connected are colour coded
(must be for some reason but now I am even more confused)
9&10 yellow
7&8 black
5&6 red
3&4 blue
1&2 green
JUSB 1 & JUSB 2 on MSI m7211
9
7
5
3
10
8
6
4
2
The manual states as follows:-
1VCC(1)
2VCC(2)
3USBO-
4USB1-
5USBO+
6USB1+
7Ground
8Ground
9No Pin
10USBOC
I am unable to fathom out which cable go where on my new motherboard
Please can someone help me!!!
beejaygee is offline   Reply With Quote
FREE instant scan
Old May 8th, 2008, 06:14 PM     #2 (permalink)
BipolarBill's Avatar
Use yer noodle. The '1' and '2' refer to sides '0' and '1' respectively.
USBOC goes to the odd pin 10.
+5V goes to Vcc
The remaining 4 are labeled + and - and can be matched that way as long as you get the side right.
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old May 10th, 2008, 04:55 AM     #3 (permalink)
Your guidance has been a great help I may have another query for you later as I have got some more cables to sort........ again thank you very much.
Old May 10th, 2008, 05:04 AM     #4 (permalink)
Banned
Keymaker's Avatar
Send a message via ICQ to Keymaker Send a message via Yahoo to Keymaker
You don't work for the bomb squad?
Keymaker is offline   Reply With Quote
Old May 10th, 2008, 07:09 AM     #5 (permalink)
USB and 1394 connections are unique in that you can blow stuff up with them if you get it wrong. As long as you get ground and Vcc/+5V right, you're safe. The other connections are data connections and you won't burn anything up with them. Those are safe to experiment with.
Audio connections are benign. You can safely use trial and error to set them up.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
okay now i am mad super gerbil General Tech Discussion 12 October 13th, 2005 05:24 AM
Would you be mad if... Smidley IMO Community 12 May 19th, 2005 08:23 PM
Now i'm getting mad... SiLVerBuRn Technical Support 30 August 27th, 2004 02:26 PM
Now we're REALLY mad: Theophylact IMO Community 8 August 6th, 2003 09:13 AM
PC Gone Mad lost-and-found Technical Support 10 August 5th, 2002 10:30 AM
Is It Just Me? (557)
Transfering balances from one credi.. (6)
Linksys WRT54G (5)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (15)
1 internet. 1 house. 3 computer. ho.. (14)
SSD's, RAID, and External Backup (7)
is there a way to Grep for a sp.. (0)
Painfully Slow eSata External 1.. (0)
Help with broken bracket from A.. (3)
RAID 0 External Drive Slow/Fail.. (2)
Switching HDDs (1)
new kid (0)
Benefits of having two separate.. (1)
Laptop doesn't stay connected t.. (10)
Hard Core Overclock (14)
