May 15th, 2008, 05:35 PM
May 15th, 2008, 05:58 PM
| | Super Stealthy Moderator
| open box board saves you $20
you might need to buy cables with the open box board otherwise there is no need to. cheaper memory saves another $20 after rebates The 120mm fan you selected won't fit that case "Cooling System 1x 80mm rear fan 120mm Fans No Side Air duct Yes"
Guess I was wrong on that I see someone said they swapped them, you might need to be prepared to mod the case though
Personally I'd go with a bit better power supply IMO aprevia isn't that good good reading on power supplies
"The true measure of a man is the degree to which he has managed to subjugate his ego."
May 15th, 2008, 06:04 PM
May 15th, 2008, 06:47 PM
| | Folding@home since 1862!
