Some advice on this build..  | | |
June 1st, 2008, 07:21 AM
I just put together this on envision, let me know if its ok or not..
Component Your Selection Price
Case: Antec Sonata III Piano Black MidTower with Antec 500w & Front USB $135.00
Intel CPU: Intel Core 2 Duo Processor E8400, 3.0GHz, 6MB Cache,1333MHz FSB, 45nm $193.00
DDR2 Motherboard: Asus P5K-E w/ Audio-GB.LAN-RAID $182.00
Case Fan: Black 120mm Case Fan $10.00
DDR2 RAM (1st stick): Corsair XMS2 Twin2X 2GB PC6400 DDR2-800, Heat Spreaders, Matched Pair $85.00
DDR2 RAM (2nd stick): NONE
DDR3 RAM (1st stick): NONE
DDR3 RAM (2nd stick): NONE
Hard Drive 1: Western Digital 320 GB, Serial ATA 300, 7200 RPM, 16 MB Cache $94.00
Hard Drive 2: NONE
CD-ROM: Major Brand 52x CD-ROM - Beige $30.00
CD-RW / DVD-RW: NONE
DVD Drive Only: NONE
Floppy: NONE
Video Card: nVidia GeForce 8800GT, 512MB, Dual DVI, TV-Out(HDTV Ready), PCIx $320.00
Monitor: Major Brand 17" CRT Monitor - Black $135.00
Modem: NONE
Sound Card: NONE
Speakers: Multimedia Desktop Speaker Set (2 Piece) - Black $12.00
Keyboard: NONE
Mouse: Logitech MX518 Gaming-Grade Optical Mouse $55.00
Operating System: Windows Vista Home Basic x64 Edition - DVD (OEM) $110.00
Other Software: NONE
AntiVirus Software: NONE
FireWire (IEEE 1394): NONE
Network Card: NONE
Wireless Networking: NONE
Router: NONE
Hard Drive Controller Card: NONE |
June 1st, 2008, 10:34 AM
I usually don't get involved in these system builds because it's really not dependent so much on the hardware as it is on the builder's skills. Quote: |
| What does that mean? No brand? A CRT? No - you want a branded monitor (Samsung, LG, whatever) and some sort of LCD. They use less power and are actually bigger per inch than CRTs. They take up less desk space too. Quote: |
| Why are you getting x64 and Vista Home Basic? You won't be happy. Drivers are difficult to find and a lot of software (many games too) won't work well on it. Get the regular flavor (x86) Vista Home Premium. You'll be happier.
That hard drive is fine, but you can double the size and get faster performance from this Western Digital for a few dollars more: Newegg.com - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
Where are you shopping? I don't know anyplace that bundles generic CRT monitors in systems anymore. You should try to shop at Newegg, MWave or ZipZoomFly. They have excellent service and great prices. MWave can put together a system for you that rocks and can most likely beat that price.
MCSE, MCP, MVP and nut job
June 1st, 2008, 11:29 AM
| | to F@H or not to F@H ?
if you plan on getting that copy of vista installed you will need a DVD drive, (not a cdrom)
vista comes on a DVD
__________________ i'm folding for techimo!! what are you doing? |
June 1st, 2008, 11:36 AM
Good catch.
Another "major brand" item.  |
June 1st, 2008, 09:05 PM
Thanks for the advice im still just a noob at building so im having someone else build it until i know enough to build it myself.. how does this update look..
Case: Enlight 7250 Mid-Tower ATX, Antec 550 Watt, 2 Front USB - Black
FSB, 45nm
Case Fan: Cold Cathode 11in Light, Blue
DDR2 RAM (1st stick): Corsair XMS2 Twin2X 2GB PC5400 DDR2-675, Heat
Hard Drive 1: Western Digital 500 GB, Serial ATA 300, 7200 RPM, 16 MB Cache
Hard Drive 2: NONE
CD-ROM: NONE
CD-RW / DVD-RW: LiteOn Combo CDRW 52x32x52x + DVD 16x - Black
Floppy: NONE
PCIx
Monitor: Acer Brand 17" LCD Monitor - Black
Modem: NONE
Sound Card: SoundBlaster Audigy SE 7.1 24-Bit (Bulk)
Keyboard: NONE
Mouse: NONE
Operating System: Windows Vista Home Premium x64 Edition - DVD (OEM) |
June 1st, 2008, 09:25 PM
do you have a link to that motherboard |
June 1st, 2008, 09:29 PM
| Quote:
Originally Posted by Cmptr-Gy-Dv do you have a link to that motherboard | yup, why is it bad? Envision Computer Solutions |
June 1st, 2008, 09:38 PM
** Please update the latest BIOS to support Intel 45nm CPU
did you see this,
and why the 5400 RAM
DDR2 1066*/800/667 Non-ECC,Un-buffered Memory
get the 1066 although I have the P5K-E wifi and if there the same you will need to overclock it to 1066,
but thats easy, |
June 1st, 2008, 09:44 PM
| | \m/(°-°)\m/
Also, your going to lose dual channel mode on your RAM unless you have 2x sticks in there. Your better off getting a 2x1Gb set then one single 2gig stick.  |
June 1st, 2008, 09:49 PM
| Quote:
Originally Posted by KarmaKiller Also, your going to lose dual channel mode on your RAM unless you have 2x sticks in there. Your better off getting a 2x1Gb set then one single 2gig stick.  |
thats true but get 2 2gigs sticks vista will use all the ram you have so the more the better, |
