explorer quickly shuts down
Currently Active Users: 2060
Discussions: 200,936, Posts: 2,379,239, Members: 246,301
Old June 23rd, 2008, 09:45 PM   Digg it!   #1 (permalink)
Question
My son just recently downloaded a patch for Wavepad, and now my windows explorer (not IE) keeps closing after accessing any of my 5 different drives on my computer.
He told me after he downloaded the patch that he clicked on the icon, the machine bluescreened . I tried doing a restore but it will only let me restore to a time after he installed the program. I mean I can open any drive see the files and folders, but very shortly after explorer shuts down.
You can access many of the files either through Windows media player, MS word or other programs you would generally use to access them, but you don't have time to view anything if you open it in explorer because explorer shuts down right away.
Needless to say I haven't given my son back to God yet, but it could happen. So does anyone have any ideas??
rezrunner is offline   Reply With Quote
Old June 23rd, 2008, 10:26 PM     #2 (permalink)
try running msconfig and disable any non-critical processes or anything you don't need.
Other than that, reinstall always works
Kenrin is offline   Reply With Quote
Need Help Quickly On Java! academy. Webmastering and Programming 1 September 27th, 2007 06:21 PM
A little help, quickly Ebisoba Technical Support 8 December 19th, 2003 09:05 PM
Need help quickly, what is the best stepping for..... Ultima Processors, Memory, and Overclocking 6 April 2nd, 2003 12:24 PM
Quickly cool your pc? bakahams7er General Tech Discussion 21 March 18th, 2003 03:03 AM
[UD] We are quickly overtaking 47 and 46 mickwish Distributed Computing 76 July 23rd, 2002 11:10 AM
windows 7 problem (6)
Is It Just Me? (2899)
Wireless Televisions. (8)
California Passes Anti-Flat-HDTV Le.. (41)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
