Thread: Temps
June 24th, 2008, 02:03 AM #1Junior Member
- Jun 2008
- 3
Temps
What is a safe temperature for my computer to be running at? I have 2 heat sensors. 1 near my processor and 1 on my hard drives.
June 24th, 2008, 06:36 AM #2
We need to know which cpu you have....What are your current temps?
June 24th, 2008, 02:18 PM #3Junior Member
- Jun 2008
- 3
AMD Athlon 64 X2 5000+
NVIDIA GeForce 8800 GT
Maxtor 400GB Sata 2 HD
Maxtor 200GB Sata 2 HD
ASUS M3A Motherboard
5 120mm Fans
2 80mm Fans
CPU Temp - 26 C
HD Temp - 24 C
June 24th, 2008, 02:24 PM #4
those temps are fine for the setup you have. I'm assuming these are idling temps, try running some benchmarks or other processor intensive things and see what your CPU gets up to.
Mobile: Thinkpad T61 | WinXP Pro | C2D T8300 CPU | 3GB DDR2 | 320GB Hybrid SSD HDD | AGN & WWAN
Desktop: Dell XPS 8300 | 3.4 Ghz Intel i7 | 8GB DDR3 | 1TB OS, 1.5TB Mirrored DATA
June 24th, 2008, 02:25 PM #5
is that your temps of your CPU & HDD at idle? (low power/performance state?)
or is that when running full throttle (gaming, or whatever?)
for idle temps, thats really good, right where they should be at... I doubt it, but if thats full bore, thats insanely good for temps...
but if those aren't, what are your peak temps?
June 24th, 2008, 03:07 PM #6Junior Member
- Jun 2008
- 3
HD Temp - 26-28 C
CPU Temp - 26-27 C
Those are the temperatures as of now. I am currently running windows media player, 3 tabs for internet and playing wow. So im definitely multi-tasking. So im assuming thats good temps?
temps
By swell22 in forum General Tech DiscussionReplies: 10Last Post: January 11th, 2006, 12:21 AM -
How to get these temps down?
By SocceRich20 in forum Technical SupportReplies: 3Last Post: February 27th, 2005, 05:11 AM -
P4P800 problem, temps are higher than the cpu temps , odd
By ZL1 in forum MotherboardsReplies: 1Last Post: November 1st, 2003, 06:21 PM -
P4 3.06 temps
By Harold7 in forum Technical SupportReplies: 24Last Post: March 20th, 2003, 03:23 PM -
HELP with temps!
By Martoch in forum Technical SupportReplies: 5Last Post: April 19th, 2002, 10:49 PM
Exactly. Too many sheep rely on law enforcement to proactively "protect" them. They are not personal bodyguards and not a personal LifeAlert nor ADT security. Their job is to enforce the laws and...
Do YOU think having a gun would...
