help rebuilding comp to work well with LCD HDTV
Currently Active Users: 1426
Discussions: 200,508, Posts: 2,374,399, Members: 245,831
Old July 24th, 2008, 03:41 PM   Digg it!   #1 (permalink)
I would like to rebuild my computer and use an LCD 1080p TV as the monitor. I want the computer to be maximized for the best picture on the LCD. I’m hopping to keep the computer rebuild to under $1000. I also want to be able to watch TV on the monitor, routing the cable through the computer (don’t know want kind of cable ill have since I haven’t moved into my new apartment yet for the next year of college). I haven’t purchased the LCD TV yet but I’m thinking of one of the fallowing:
-Samsung LN32A650 32-Inch 1080p LCD HDTV Amazon.com: Samsung LN32A650 32-Inch 1080p LCD HDTV with RED Touch of Color: Electronics )
-Sharp Aquos LC32GP3UB 32-Inch 1080p LCD HDTV Amazon.com: Sharp Aquos LC32GP3UB 32-Inch 1080p LCD HDTV, Black: Electronics
-Sony Bravia XBR-Series KDL-32XBR6 32-Inch 1080p LCD HDTV Amazon.com: Sony Bravia XBR-Series KDL-32XBR6 32-Inch 1080p LCD HDTV: Electronics
Does anyone have any experience using any of these LCDs as a computer monitor? what graphic card are you using in conjunction with the TV? I also will be playing my xbox360 on it, which one will be best for that?
My computer specs are as fallows:
MSI MS-6380E 1.0
Board: MSI MS-6380E 1.0
Bus Clock: 133 megahertz
BIOS: American Megatrends Inc. 07.00T 04/02/01 (I know, its old)
1.47 gigahertz AMD Athlon XP
128 kilobyte primary memory cache
256 kilobyte secondary memory cache
512 Megabytes Installed Memory
RADEON 9600 PRO SEC Family (Microsoft Corporation) [Display adapter]
SAPPHIRE RADEON 9600 ATLANTIS [Display adapter]
Samsung SyncMaster [Monitor] (19.1"vis, s/n H9NY947715, September 2005)
Realtek AC'97 Audio for VIA (R) Audio Controller
MAXTOR 6L040J2 [Hard drive] (40.03 GB)
DU3319J RAP538E SCSI CdRom Device [CD-ROM drive]
MITSUMI CD-ROM FX240S !B
YAMAHA CRW8424E [CD-ROM drive]
3.5" format removeable media [Floppy drive]
SCSI/RAID Host Controller
NEC PCI to USB Enhanced Host Controller (B1)
NEC PCI to USB Open Host Controller (2x)
VIA Rev 5 or later USB Universal Host Controller (2x)
Im guessing ill have to upgrade most of my system since its so old. Im having the most trouble figure out what kind of graphic card I should get to work the best with an LCD HDTV. I plan on gaming on the computer too. Any recommendation on how to upgrade my computer and/or which tv to buy would be a big help. thanks
seaman87 is offline   Reply With Quote
Old July 24th, 2008, 04:06 PM     #2 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
Since we don't want to put the cart before the horse its best to decide now if you want to upgrade the entire system or just add in a card that will work for now. AFAIK the 9600's you have now "should" run the monitor just fine, you probably won't get the best resolution but they might work.
If you are just trying to add a card to the current set-up you'll need something AGP based.
Posting a budget and/or deciding if you want a full upgrade or not is the best place you can start.
Linus Torvalds
RicheemxX is offline   Reply With Quote
Old July 25th, 2008, 01:18 AM     #3 (permalink)
i think im going with a full upgrade. im basically trying to figure which are the best components to run a HDTV as my monitor and then figure out what i need to upgrade in my current computer to facilitate tho HDCP components. if that means up doing a full upgrade so be it, im just hopping to keep the budget at $1000. and im starting to lean towards the Sharp Aquos LC32GP3UB 32-Inch 1080p LCD HDTV (Amazon.com: Sharp Aquos LC32GP3UB 32-Inch 1080p LCD HDTV, Black: Electronics).
so the question is which graphics card would you recomment and what would i have to upgrade to make it work?
thanks for your help
Old July 27th, 2008, 02:25 AM     #4 (permalink)
cadetstimp's Avatar
Make sure your video card driver can run the native resultion of the LCD (1920 x 1080 for HD 1080 sets). This will give you the absolute best, clear and crisp image.
You might want to check out Viewsonic - they started as a computer monitor company and have been making HD LCD sets for awhile. They're based out of CA and have a better than average warranty/customer service.
They have an online Outlet store for factory refurshibed and if your near their headquaters in Walnut, CA... you can buy/pick up directly from the manufacturer!
Welcome to ViewSonic Store... &nbsp ViewSonic Outlet
The LCD HD TV will have multiple inputs and the remote will switch the computer/tv sources for you. DVI and HDMI are very similar - HDMI includes audio which computer DVI doesn't use. You would be able to get a DVI to HDMI cable that would connect your computer directly to the TV- other wise you would have ot use the SVGA input
cadetstimp is offline   Reply With Quote
Olevia 32 inch LCD HDTV FRANKSnBEANS IMO Community 13 September 5th, 2007 08:51 PM
LCD Monitor vs HDTV Minimum Graphics Cards and Displays 8 January 14th, 2007 08:14 AM
Watching HDTV on comp thru Cable? Jon11582 Graphics Cards and Displays 4 April 17th, 2005 10:52 PM
FS: Samsung 17" LCD HDTV Darknyt Traders Forum: Buy, Sell, Trade 0 March 3rd, 2004 03:16 PM
rebuilding old 166 -- CD's won't work milehigh Storage Related 29 February 10th, 2003 04:02 PM
Is It Just Me? (1635)
Review My Build (5)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
windows 7 retail and rtm (0)
sell cvv us-uk-eu-au...very good. who.. (0)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
