July 24th, 2008, 06:12 PM #1
2 users/same computer at the same time?
My wife and I have discussed this a bit, and Im trying to nail down a way for us both to use one computer at the same time - we want to do this together.
Is there any way to use 2 different displays and 2 keyboards/mice along with the whatever internet software needed and OS for both of us to surf simultaneously to different sites while using the same computer(only 1 computer).
I haven't found anything yet, does anyone have any suggestions?
EDIT: I need to mention that I want to run WinXP if possible. I dont need/want to re-learn a new OS unless I have to. . .Last edited by no1_vern; July 24th, 2008 at 06:19 PM.
dulce bellum inexpertis
July 24th, 2008, 06:23 PM #2
Free 2-User version of Userful Multiplier - 2 users from 1 computer
I'm not sure how well it works. But AFAIK, this is the only way.Q6600@4Ghz | i7 920@4.4Ghz |E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
July 24th, 2008, 06:31 PM #3
Thanks Karma, but that is a linux solution. I might go that way, but I'd rather stick with WinXp if possible.
July 24th, 2008, 06:54 PM #4
Everything I've read said that windows seems to have an error when you plug in more then two keyboards. IDK though, I've personally never tried it.
I know on my old pentium d CPU it had some kind of feature that you could hook a terminal up to it, and have multi users at once. But from what I remember, the terminal thing costs as much as another older CPU.Q6600@4Ghz | i7 920@4.4Ghz |E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
July 24th, 2008, 07:56 PM #5
What is the restriction to only having one computer?
July 24th, 2008, 08:35 PM #6
Cost. I was hoping for a free solution so I dont have to spend 100+ for a new computer.
July 24th, 2008, 11:42 PM #7
I just don't see it happening. Now, a laptop with external display and keyboard MAY work, but I don't suppose you have a laptop do you?
July 25th, 2008, 03:37 PM #8
Unless you have a decent, mid grade multicore computer, your going to get horrible performance as that would essentially be taking multi-tasking to the max.
Your better off planning on getting a new computer, or a refurb laptop for the second computer then try using one computer for two people.
July 27th, 2008, 01:09 AM #9
Hmm... maybe fit 2 computers into one case.
I know...it's 2 computers, but you'll still get the warm and fuzzy feeling of sharing "a computer"
Only way I know of because you'll always be stuck with one curser/mouse pointer. It is possible to use two mice/keyboards but they will always be fighting for use of the same cursor/pointer.
March 25th, 2009, 12:50 PM #10Junior Member
- Mar 2009
- 1
Another Two User Question
I want to know if my IE history can be accessed by my partner who also uses the same laptop, from their IE screen, without going to my IE screen?
I have my IE screen on auto-delete for any and all sites I visit; but my partner is much more computer savy than I, and I'm wondering if they can somehow create a 'link' of some-sort from my IE screen to theirs, thus finding out what sites I visit?
March 25th, 2009, 01:58 PM #11
March 26th, 2009, 09:03 AM #12Member
- Mar 2005
- 106
If someone has access to your computer then more or less anything you do can be found out. Windows passwords can be cracked pretty easy and also spy / keylog type software can be installed to capture every web site, email and of course Instant Message you write.
Isn't Technology Wonderful?
January 28th, 2010, 01:01 AM #13Junior Member
- Jan 2010
- 1
It's not crazy..
For example: I want my media center program, Boxee to always be running on my HDTV. I don't care what user is logged into the PC with the LCD monitor attached--I want Boxee on the TV at all times.
No OS that I am familiar with has the ability to segregate physical login from display. Server OSs (Windows, OSX, *Nix) readily allow for multiple virtual logins with virtual display; but this doesn't meet the need. What you really want is the ability to designate a physical display to a user.
Interesting idea, One computer, 2 users at the same time.
By nunyadam in forum Applications and Operating SystemsReplies: 2Last Post: January 21st, 2008, 07:27 PM -
Users are connected to your computer??
By sensi in forum Applications and Operating SystemsReplies: 4Last Post: October 19th, 2005, 11:38 PM -
Poem For Computer Users over 50
By Messiah89 in forum IMO CommunityReplies: 6Last Post: April 8th, 2004, 11:56 AM -
North Korea claims to invent health drink for computer users
By RobRich in forum IMO CommunityReplies: 7Last Post: May 12th, 2003, 10:21 PM -
NEW COMPUTER TIME!!!!!!!
By THE V_I_R_U_S in forum General Tech DiscussionReplies: 22Last Post: April 29th, 2003, 06:30 PM
that was easy, if only deleting the partition was that simple.
