Thread: $700 Computer , Help me please!
July 27th, 2008, 11:49 PM #1Junior Member
- Jul 2008
- 14
ok so im saving my money and am going to buy computer parts from newegg.com and make it from scratch , i have all the parts bookmarked and i can share them and just need someone to tell me if there a good deal and they are all compatible with eachother
in other words - will this work ?
keep in mind , im kinda new at making , know how tho , and i want to save money...please help a noob in trouble
Case -
Newegg.com - APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case - Computer Cases
Power-
Newegg.com - Thermaltake Purepower W0100RU 500W ATX 12V 2.0 Power Supply 115/ 230 V UL, CUL, TUV, FCC, and CB certification - Power Supplies
MOBO-
Newegg.com - MSI K9A2 Platinum AM2+/AM2 AMD 790FX ATX AMD Motherboard - AMD Motherboards
CPU-
Newegg.com - AMD Phenom 8450 Toliman 2.1GHz 3 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Triple-Core Processor - Processors
Ram-
Newegg.com - CORSAIR XMS2 DHX 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
HD-
Newegg.com - Seagate Barracuda 7200.11 ST3320613AS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
Video-
Newegg.com - EVGA 384-P3-N851-AR GeForce 8800 GS 384MB 192-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
DVD-
Newegg.com - ASUS Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 14X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe - CD / DVD Burners
Windows XP-
Newegg.com - Microsoft Windows XP Home With SP2B for System Builders 1 Pack - Operating Systems
July 28th, 2008, 12:25 AM #2
Looks like a good build to me. All parts are compatible and should work well together.
July 28th, 2008, 03:40 PM #3Ultimate Member
- Oct 2003
- Location
- Canada [Maritimes]
- 1,260
for another $20 get Vista 64 bit...an take advantage of that
4 gigs of ram
Newegg.com - Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - Operating Systems
July 28th, 2008, 03:49 PM #4
July 28th, 2008, 04:06 PM #5
While Thermaltake isnt a bad brand, their power supplies are a little weak
This Antec is the best bang for buck at the moment and is as cheap BEFORE the rebate...
Newegg.com - Antec Basiq BP500UB 500W ATX12V Version 2.01 Power Supply 100 - 240 V UL, CB, CE, CSA, TUV, FCC - Power Supplies
Unless your specific goal is overclocking, i think you could trim a little off the memory price...
Newegg.com - pqi POWER Series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
And I would never pay over $25 for a DVDRW
Just get a good Liteon and save $15
Newegg.com - LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 20X DVD±R DVD Burner - CD / DVD Burners
I also dont see the point in getting a crossfire motherboard and an Nvidia card
I have a hard time justifying a motherboard for over $100 unless you have a VERY specific reason for it...
If it were my build, I'd probably be looking aty something like...
Newegg.com - ABIT AX78 AM2+/AM2 AMD 770 ATX AMD Motherboard - AMD Motherboards
And last and least... If I was spending +$50 on a case, I'd get one that was a little more classy, had better airflow, and was alot more solid
That apevia is cheap, thin, and has poor airflow in comparison to other cases
I would put my money into something like a coolermaster or something...
Newegg.com - COOLER MASTER Centurion 534 RC-534-KKN2-GP Black Aluminum & Mesh bezel / SECC Chassis ATX Mid Tower Computer Case - Computer CasesLast edited by JPMiller; July 28th, 2008 at 04:12 PM.
July 28th, 2008, 04:25 PM #6
I would get an Intel Q6600 setup instead.
Newegg.com - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Processors
Newegg.com - ABIT AB9 Pro LGA 775 Intel P965 Express ATX Intel Motherboard - Intel Motherboards
Newegg.com - GIGABYTE GA-EP35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Intel Motherboards
Newegg.com - Intel BOXDP35DPM LGA 775 Intel P35 ATX Intel Motherboard - Intel Motherboards
I'd go with this ram:
FRYS.com*|*OCZ
Why are you getting a 320GB drive that costs $70 when you can get a 500GB drive for the same price?
Newegg.com - SAMSUNG Spinpoint F1 HD502lJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
I'd also get Vista Home Premium X64.
Make sure you watch those combo deals. Like with that 8800 GS you can get 2GB of this ram for free.
Newegg.com - OCZ Platinum Revision 2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory"The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
July 28th, 2008, 04:28 PM #7Junior Member
- Jul 2008
- 14
thanks guys , ill check into your option , and i just didnt want vista cause i have vista atm and everyone complains about it and how xp is better for gaming ??
and the vista i got atm is X32 or w/e , and is this a good price for a gaming rig or can it get lower?
July 28th, 2008, 04:36 PM #8Junior Member
- Jul 2008
- 14
hmmm should i go with the Quadcore and the lat intel mobo u suggested?
im new and i wanna save money , but have a good gaming computer,.....
the one i got atm is a acer apsire amd64 athlonX2, viasta , ati x1650SE, 2gm ram , and 4200+ cpu.
July 28th, 2008, 04:42 PM #9
I was leaning towards the Abit motherboard, it had the most features (at least the most on the board features, I am not sure about the BIOS).
I have a Q6600 desktop with 4GB of ram and that same 8800 GS and it is great.
Everybody complains about Vista because that is what is popular and they think it makes them cool.
That isn't too bad of a price, I got mine for $950, but it came with a 24" LCD as well, but some of the parts are cheaper, like the mobo."The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
July 28th, 2008, 04:43 PM #10Junior Member
- Jul 2008
- 14
ok i guess ill start saving my money
i got the 19" lcd samsung alredy, and the keyboard blah blah , thanks guys , when i put all the parts together do you expect any problems? or just put it together , boot vista , and it will work?
July 28th, 2008, 04:47 PM #11Junior Member
- Jul 2008
- 14
$660-est ...pretty good deal then , since alienware comps are 1.6k LOL
July 28th, 2008, 04:48 PM #12
How long before you plan on building it? Prices can change significantly weekly, or new parts can come out that are a much better deal.
There should be no issues putting it together, as long as all the parts work. There is always a small chance of getting a bad component."The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
July 28th, 2008, 04:49 PM #13Junior Member
- Jul 2008
- 14
well mabe a month LOL , im only 16
but yeah once i get the money ill buy them , or check for deals if they have changed.
July 28th, 2008, 04:58 PM #14
Once you get the money you'll want to start another thread or bump this one again. Prices will probably change quite a bit over the next month.
July 28th, 2008, 05:12 PM #15Junior Member
- Jul 2008
- 14
should i pay for all this , or just mabe some ram and a new video card for this computer?
Ase380-Ed423a
3.4 vista score
4200+cpu x2 amd64
2gb dd2 ram
ATi X1650SE
250gb hd
DVD-dual drive
vista X32 home premium
July 28th, 2008, 05:26 PM #16
I doubt youll see much, if any benefit going from 2 to 3 gigs memory
better off upgrading the CPU and video card.... (not that it would hurt to pick up that fry's deal)
Newegg.com - AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 125W Dual-Core Processor - Processors
and whatever deal is best for an 8 or 9 series Nvidia cardLast edited by JPMiller; July 28th, 2008 at 05:29 PM.
July 28th, 2008, 05:31 PM #17Junior Member
- Jul 2008
- 14
ok so heres my specs.......so it would be better to just upgrade the cpu and the gpu on this rig then? that would save money , should i get a quad core or the 6000+ u suggested , and what card the 8800gs? , will it be easy enough for me to do the switching , i took this video card out and put new ones so thats easy enough......ps , does everyone here like anime or what ? XD
-SPECS-
Code:Computer: Computer Type ACPI x86-based PC (Mobile) Operating System Microsoft Windows Vista Home Premium OS Service Pack [ TRIAL VERSION ] Internet Explorer 7.0.6000.16609 DirectX DirectX 10.0 Computer Name HP-PC User Name HP Logon Domain [ TRIAL VERSION ] Date / Time 2008-07-28 / 14:28 Motherboard: CPU Type DualCore AMD Athlon 64 X2, 2200 MHz (11 x 200) 4200+ Motherboard Name Acer Aspire E380 Motherboard Chipset nVIDIA nForce 6100-4xx, AMD Hammer System Memory [ TRIAL VERSION ] DIMM1: Hynix HYMP512U64CP8-C4 1 GB DDR2-533 DDR2 SDRAM (5-4-4-12 @ 266 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz) DIMM2: Hynix HYMP512U64CP8-C4 [ TRIAL VERSION ] BIOS Type Award (02/07/07) Communication Port Communications Port (COM1) Communication Port Communications Port (COM2) Communication Port Printer Port (LPT1) Display: Video Adapter Radeon X1650 Series (256 MB) Video Adapter Radeon X1650 Series (256 MB) 3D Accelerator ATI Radeon X1650 SE (RV516) Monitor Samsung SyncMaster 920LM/920NW [19" LCD] (H9FM413630) Multimedia: Audio Adapter Realtek ALC888/S/T @ nVIDIA MCP61 - High Definition Audio Controller Storage: IDE Controller NVIDIA nForce Serial ATA Controller IDE Controller NVIDIA nForce Serial ATA Controller IDE Controller Standard Dual Channel PCI IDE Controller Storage Controller Microsoft iSCSI Initiator Storage Controller SCSI/RAID Host Controller Storage Controller SCSI/RAID Host Controller Disk Drive Generic- Compact Flash USB Device Disk Drive Generic- MS/MS-Pro USB Device Disk Drive Generic- SD/MMC USB Device Disk Drive Generic- SM/xD-Picture USB Device Disk Drive HDT72252 5DLA380 SCSI Disk Device (250 GB, 7200 RPM, SATA-II) Optical Drive CM2055Z FVY507H SCSI CdRom Device Optical Drive HL-DT-ST DVD-RW_GSA-H41N ATA Device Optical Drive QI1633V CEN546O SCSI CdRom Device Optical Drive QI1633V CEN546O SCSI CdRom Device SMART Hard Disks Status Unknown Partitions: C: (NTFS) [ TRIAL VERSION ] Total Size [ TRIAL VERSION ] Input: Keyboard HID Keyboard Device Keyboard HID Keyboard Device Mouse HID-compliant mouse
July 28th, 2008, 05:50 PM #18Junior Member
- Jul 2008
- 14
would the Newegg.com - EVGA 384-P3-N851-AR GeForce 8800 GS 384MB 192-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
video card fit in my computer? , ill get this and the quad or triple core phenom?
July 28th, 2008, 05:53 PM #19
While Im not 100% sure, I doubt your motherboard will be compatible with a tri or quad core CPU...
Your also most likely looking at a power supply upgrade as well
As far as that card "fitting"... you'd have to measure the interior of the case where the card will go
July 28th, 2008, 05:54 PM #20Junior Member
- Jul 2008
- 14
eeerrrrrrrrgggggg
ok so do you need more info to know this cause im wanting to order the parts i want right this minute
since i can afford $250 lol
$700 under build
By rylenolflu in forum General Tech DiscussionReplies: 0Last Post: July 10th, 2007, 06:39 PM -
Best Build for $700.00
By DarkStar02 in forum General Tech DiscussionReplies: 19Last Post: December 13th, 2005, 12:01 AM -
COMPLETE Gaming computer for less than $700 with EVERYTHING (LCD monitor too!)
By DarkStar02 in forum General Tech DiscussionReplies: 18Last Post: August 31st, 2005, 12:57 AM -
$700!
By joker_927 in forum Graphics Cards and DisplaysReplies: 1Last Post: October 27th, 2003, 03:09 AM -
New Logitech MX -700:)
By cracked in forum General Tech DiscussionReplies: 2Last Post: December 24th, 2002, 12:39 AM
Watch Star Trek Into Darkness Online. After the crew of the Enterprise find an unstoppable force of terror from within their own organization, Captain Kirk leads a manhunt to a war-zone world to...
Watch Star Trek Into Darkness...
