A CD-R I burnt can't be read on MY computer
August 7th, 2008, 02:46 AM
Hi, this is my first time at TechIMO
I just finished burning a bunch of manga onto a CD-R. For those of you who don't know, this consists of all picture files (JPEGs, GIFs, etc.) as well as a few thumbs thrown in here or there.
After I burned it, I ejected the disk and then placed it back in to see if it would work. It didn't.
I then tried looking at the files on the computer of a friend of mine. It worked there.
Oh, my specs
Um... it's a pretty old computer, an IBM Thinkpad T41
Intel Pentium M processor 1.6GHz
1 GB of RAM
I used IMAPI to burn the files
My CD/DVD drive is a Toshiba DVD-ROM SD-R9012 (I think)
What is need is a way to view the files on my computer. If anyone can help me, I'd appreciate it alot! |
August 7th, 2008, 05:40 AM
There are multiple lasers in new drives. Your playback laser may have died or the lens may be dusty. Open the tray and clean the lens with alcohol.
If no joy, you will need a replacement.
MCSE, MCP, MVP and nut job
August 9th, 2008, 07:34 AM
| | Let's go, Hokies!
I don't think you're burning anything with a DVD-ROM. Nor do I suspect a laser problem, if you are able to burn the discs.
IMAPI is the Windows CD burning wizard. This generally makes for very compatible discs, but your drive may be finicky about media. Can you tell us what brand and speed of discs these are? |
August 10th, 2008, 06:08 AM
| Quote:
Originally Posted by osprey4 I don't think you're burning anything with a DVD-ROM. Nor do I suspect a laser problem, if you are able to burn the discs.
IMAPI is the Windows CD burning wizard. This generally makes for very compatible discs, but your drive may be finicky about media. Can you tell us what brand and speed of discs these are? | I used a 52X Memorex CD
While burning though, I set it to 2X as I read somewhere that it might help if I did that. |
August 10th, 2008, 04:53 PM
| | Let's go, Hokies!
Try a different brand. Memorex are famous for their unreliability. Maxell (made in Japan), Taiyo Yuden or Verbatim are good. |
August 11th, 2008, 05:22 AM
Damnit, I bought them in America (Cause I'm moving to China for two years cause of my dad's work) and I doubt the ones I buy here are any good.
Oh well, I'll try those when I go back.
Thanks! |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Computer wont read any CD | TheFuture | Technical Support | 1 | October 14th, 2006 04:55 PM | | Computer Will Not Read New Memory Stick | iamchaos | Processors, Memory, and Overclocking | 0 | February 2nd, 2005 07:51 AM | | Computer doesnt read all the memory | jentzsch | Technical Support | 2 | May 30th, 2004 08:31 AM | | Wanted WTB Complete Computer, Please Read.... | Gothika | Traders Forum: Buy, Sell, Trade | 4 | February 18th, 2004 08:46 AM | | Counterstrike crashes computer-Read all about it! | Redwolf | General Gaming Discussion | 0 | December 29th, 2001 08:38 PM | |
