August 28th, 2008, 08:26 PM
August 28th, 2008, 08:40 PM
| | Folding@home since 1862!
Hi.
A couple of thoughts here.
1. Unless you plan on going Tri-SLI (which is a waste of $) there is no need for the 780i boards. The 750i boards are a great option though. They are much cheaper, and have pretty much all the goodies.
2. I myself would put no less the 600watts into that system. I have a 680i Mobo, OC'd Q6600,9800GTX,2Gb's or RAM, and I think I'm pushing it. Really, a quality 600-700w PSU would be right for your system IMO.
3. I'd wait till they release the GTX260 +. They are coming out very soon. They'll use a die shrink, less power, run cooler, and probably OC better also. I'm not for sure when, but I know LOTS of people are waiting for them.
4. The RAM is okay. I myself would be getting these Newegg.com - OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
Just my two cents.. |
August 28th, 2008, 08:46 PM
I'm not the expert on this, but a lot of your stuff is based on SLI; are you going to use it?
If not, I imagine you can save a few bucks and scale back.
Windows 3.1, 95, 98, XP, Vista...all love memory. Get 4 gig for Vista and make sure you can expand to 8. I haven't checked in a while, but I recall memory being pretty cheap these days. In the past, I've paid $100 for a 512K stick and my last TWO gig a few months back cost me $80  |
August 28th, 2008, 08:48 PM
I would go with a better power supply, as karmakiller suggested.
Hold out a little while longer for the GTX260, as prices are falling on the regulars cause the + is about to hit the shelves. Also there has been a few sites within the last few days selling the GTX 260's for $180.
Last but not least i run Vista Ultimate fine with 2GB's of memory
Ocz's platinum rev.2 xtc to be exact. As far as the memory goes it really depends on what your going to be using the system for. |
August 28th, 2008, 10:14 PM
That's a good build. What do you plan on using the computer for? Are you going to try and overclock it?
__________________ How come Sour Cream can expire? |
August 28th, 2008, 10:18 PM
Thanks alot for all the input.
Ive been going back and forth between the 750i and 780i. I doubt ill ever utalize the tri-sli or even the sli but ill probably end up going with the 780 just because of the 2 extra sata ports. (Building this with long-term in mind) And that way can also throw the gfx card all the way to the right to avoid some of the heat comming from the north bridge.
I dunno how I missed that RAM. Ill take an extra 2 GB for 5$ more; thanks for the link KarmaKiller.
What do you think about this PSU: Newegg.com - COOLMAX CUG-700B 700W ATX 12V( V.2.2) SLI Certified CrossFire Ready Modular Active PFC Power Supply - Power Supplies
I havent looked into PSU ... is this good for the price?
Dunno if I can wait for the 260+. I did a quick google but didnt find a release date; anyone know of a ballpark date or month when its commin out?
Umm I really just need to update my comp. Im willing to fork over a decent ammount of money so that this build lasts me for awhile. I know Ill mess around with the OC settings when I first put it all together; but unless I can actully notice a difference Ill probably end up reverting it back to its original settings to try and keep the heat down and the longevity up.
August 28th, 2008, 10:50 PM
I'll look for the link for the + release date.
As far as the PSU, I would not get that particular one. There are better choices out there. I can link you to some, but basically you want one of these:
Corsair
OCZ
Silverstone
PC Power&Cooling
FSP/Sparkle
Tagen/ABS
Those are the "big" names as far as quality. There are more, but that's just the one's I thought of of the top of my head.
EDIT:
Release date info..Supposed to be by the end of next month. Where Is Gtx280+/gtx260+??!! - Overclock.net - Overclocking.net
August 28th, 2008, 11:43 PM
| | SoMuchAnime-SoLittleTime
Spending $240 on a motherboard is a huge waste unless you intend to use all of it. You can get more than adequate boards for under $100.
If you need more SATA ports in the future you can pick up a 2 port SATA controller card for $10 or a 4 port for $25.
Instead of the GTX 260 I'd go with a 4870.
The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one.
August 28th, 2008, 11:52 PM
August 29th, 2008, 12:07 AM
| | Pants Optional
You can get the OCZ at Newegg for $20 less if you don't mind using MIR's, also the shipping is free. Otherwise, nice PSU and total build.
__________________ Take comfort in the fact that, though you stand tall and alone, others take shelter in the shadow you cast. |
