The name of the file is misc.bin, and I'm hoping to find some sort of text file in there, most likely a txt format one. If it helps any, the bin file is located in Median 2008's 1.57b patch. I used WinMPQ to open it and looked inside of 1.57b and 1.56. I noticed that the misc.txt file was missing from 1.57b and that the misc.bin file was double its size from 1.56. So I'm thinking that maybe the txt file is hidden in there, or something that I can salvage to recreate the file and add the things I need to it.
