How to test my system stability?
Currently Active Users: 1669
Discussions: 200,958, Posts: 2,379,514, Members: 246,328
Old May 10th, 2002, 08:02 PM   Digg it!   #1 (permalink)
Send a message via AIM to HumorPalace
Hey, how would you guys recomend i run my system at full load, so i can test the cpu/system temps and what not? Are there any programs that will run it at full load for you or should i just load up a game such as counterstrike and let it idle for a few hours ingame or what?
HumorPalace is offline   Reply With Quote
Old May 10th, 2002, 08:10 PM     #2 (permalink)
Tekk's Avatar
Umm..hmmm...as far as I know you could try 3DMark2001 and that would run the system at full load (and your graphics card at full load). That'll see if the temps of both your vid card and CPU will overheat.
And yes you could just run a game or you could even run a demo if you have say Q3 or UT. Get a really intense demo that has alot of stuff happening so that you can truly test a fully loaded system.
YAH! I knew you'd be jealous
Tekk is offline   Reply With Quote
Old May 10th, 2002, 08:12 PM     #3 (permalink)
Si vis pacem, para bellum
daveleau's Avatar
Send a message via ICQ to daveleau Send a message via AIM to daveleau Send a message via Yahoo to daveleau
There are several options for this. I use the distributed computer programs out there, like ECCP or UD project applications to test stability ( http://www.techimo.com/teams.html ). They run the system at 100% except when you are using the system, then it scales back to let the CPU handle whatever you are doing. Also, you can run loops of 3D Mark ( http://www.madonion.com/ ).
Good luck. A grat program is Motherboard Monitor ( http://mbm.livewiredev.com/download5.htm ). This will check temps for you. An Intel CPU shouldn't go above 50C (not sure about PIV specs) and an Athlon should not go above 60C.
Good luck
Dave
daveleau is offline   Reply With Quote
Old May 10th, 2002, 08:14 PM     #4 (permalink)
Best To Avoid Me
Martoch's Avatar
Here's what you need to get your cpu at 100% without having to open any other applications.
http://www.voodoofiles.com/1109
Martoch is offline   Reply With Quote
Old May 10th, 2002, 09:11 PM     #5 (permalink)
norml.org
thekingofpain's Avatar
I use the Sandra burn in feature for about 3 days...
thekingofpain is offline   Reply With Quote
Old May 10th, 2002, 09:40 PM     #6 (permalink)
engracio's Avatar
HumorPalace,
My suggestion on how to find out how stable your box is to load any one of our Distributed Computing projects, join the team and run your computer for about 7 to 10 days. Make sure you run it 24/7 to make darn sure it really is stable. Check on your stats every day or so to make sure that it is really running 100% cpu and the DC is sending out results 24/7.
Trust me a few hours of games or benchmark is not really enough to maxed out the cpu. You know, tire out the system. So 7 to 10 days minimum. Enjoy building your box and testing it.
Don't forget to tell your new teamates that you have joined.
e
Life is GOOD, Suck it up....
Besides you only die once.
Seven used, two to go
engracio is offline   Reply With Quote
Is It Just Me? (2960)
Print spooler problem (15)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
