help with compaq nc6000
Currently Active Users: 1959
Discussions: 200,936, Posts: 2,379,217, Members: 246,300
Old September 20th, 2008, 08:22 AM   Digg it!   #1 (permalink)
Can anyone help me with my hp compaq nc6000??? im having hardware problems its an old laptop now but has always worked fine,now it wont always turn on it starts to boot up then after about 5secs turns back off again but when it does turn on some times the screen just turns off on its own but the fans carry on runing,ive looked on ebay and theres alot of them with the same problem so im guessing its a common problem,i want to fix it but dont want to buy parts i dont need as the laptop not worth that much anymore.
Would be gratefull for any input
thanks
brett
brett668 is offline   Reply With Quote
Old September 20th, 2008, 06:09 PM     #2 (permalink)
BipolarBill's Avatar
It's probably overheating because the cooling tract is clogged with dust. Get a can of compressed air and use it to blow air into the intake on the bottom of the laptop while it's running. If you feel adventurous, do a partial disassembly and dust it out good.
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old October 1st, 2008, 01:25 PM     #3 (permalink)
Thumbs up
FIX
Item #10 in this post is what I found to be the correct fix to this common Nc6000 problem.
HP NC6000 hard to start then locks up - Troubleshooting Dead Machines
johncray is offline   Reply With Quote
hp compaq nc6000 problems mickydej Mobile Computing 175 October 27th, 2009 05:46 AM
Compaq nc6000 Frostman43 Technical Support 0 August 7th, 2008 08:44 PM
HP compaq nc6000 'print screen' button Penny...x Technical Support 8 August 4th, 2008 02:24 PM
HP Compaq nc6000 battery issue mad-hatter General Tech Discussion 3 January 14th, 2006 05:54 AM
Is It Just Me? (2893)
Wireless Televisions. (8)
Obama the Muslim (14)
Modern Warfare 2 freeze (13)
windows 7 problem (3)
Point and Shoot Camera Suggestions. (1)
CPU fan stops spinning randomly (3)
wireless user (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
