My 1500 build(monitor-keyboard-mouse-OS)
Currently Active Users: 1535
Discussions: 200,985, Posts: 2,379,851, Members: 246,348
Old October 5th, 2008, 12:40 AM   Digg it!   #1 (permalink)
Newegg.com - Once You Know, You Newegg
Pretty good huh? =p
oldfolks123 is offline   Reply With Quote
Old October 5th, 2008, 01:38 AM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Not bad.. I still think you could do better. And probably save some money, but that's just me.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old October 5th, 2008, 02:01 AM     #3 (permalink)
hehe yea i could i could get it down to 1000 and still have all the stuff i do rite now i found a much cheaper monitor same size but its likt 6ms or somtin and i found a cheaper video card thats just as good and cheaper mobo. but my last build cost this much and didnt include a OS monitor case keyboard etc so this is good to me =p lol
Old October 5th, 2008, 03:05 AM     #4 (permalink)
PC Upgrade Procrastinator
ShyguyXPC's Avatar
you have 2 DVD ROM's & no DVD Burners in that list? don't you need one of those?
If your going to use an aftermarket CPU cooler, grab the Intel Q6600 OEM version for $179.99, ten bucks cheaper than the Retail that includes the stock Cooler.
Old October 5th, 2008, 10:31 AM     #5 (permalink)
sry i accidently put 2 of um when i was replacing the OEM ones for retail versions. But i just deleted the CPU cooler i got it because some people say the heatsink and fan that comes with it SUCKS even if u dont plan on overclocking it sucks.
Old October 5th, 2008, 01:26 PM     #6 (permalink)
Super Duper Member
pullmyfoot's Avatar
Get the WD caviar black 640 gig drive instead. A little more space and much faster. Also, for that screen size you hardly need 1gig of video card memory. 512mb is enough. I would look into one of those dual slot ones because the stock cooling on the single slot verson kinda sucks. Mine runs at 86 degrees celcius on full load (at 45% fan speed). Any more than that and it becomes audible over my PSU fan.
pullmyfoot is online now   Reply With Quote
Old October 5th, 2008, 01:43 PM     #7 (permalink)
Hmm as you know i dont know mcuh about all this computer stuff liek cooling but i know what is good and what is bad and you lost me at...I would look into...so on...lol and i would rather exceed the standard then meet it =p
Old October 5th, 2008, 11:41 PM     #8 (permalink)
ShyguyXPC's Avatar
the stock CPU coolers are fine for running at stock speeds, who ever told you that doesn't know what their talking about or is running a crappy cooling setup for their PC... providing you have a proper cooling setup for Intake & exhaust fans, cable management & what not, the stock cooler should work fine for stock speeds & minimal to sometimes moderate overclocks...
looked at the list, edited it a bit, a mere 3 cents away from $5 cheaper than your original list...
I changed the vid card to a 512MB model with a dual slot design to vent heat out the back (factory Overclocked too, 650MHz vs 625 & 2000MHz vs 1986...),
changed the hard drive to a 500GB model with 16MB cache instead of 8MB,
Swapped out the Arctic Silver 5 for Arctic Silver Ceramique,
Ditched the Rosewill 120mm fan for a set of 2 120mm Coolermaster transparent Blue LED fans, & a single version for a total of 3 (if your going to replace the cases fans, you'll need 3 of them & not just one like you had) the Coolermasters are pretty quiet & decent cooling as I have the one pair in my 2nd PC,
Changed the Logitech speaker set for a different more powerful & better set of Logitech 2.1 speakers,
Ditched bother DVD-ROM's for two DVD Burners (DVD ROM's ONLY play DVD's & CD's, they DO NOT Record Data to Discs...), ones a lightscribe burner the other isn't, both are OEM's but you can easily use one of the Free downloadable Media burning apps like CD BurnerXP Pro or similar ones...
I ditched the Neon light, trust me with the LED's in the fans you won't need the extra Neon light... the Coolermaster twin pack of fans, the LEDs are SUPER bright, add in a 3rd fan as I did on the list, & it'll be enough to light of the inside of the case... besides the Neon light can be added later down the road if you feel you really need it... best to just see how the current setup looks & go from there, rather than stock up on parts you may not need or decide not to use after getting them. especially small cheaper priced parts like that... also why I switched the thermal paste, its a dollar cheaper, & the stock cooler comes with a layer of thermal paste on it already, if applied properly you won't need to crack open the AS paste, but its nice to have on hand down the road if you replace the heatsink or need to remove the heatsink & reattach it, applying a new layer of paste after cleaning the old stuff off.
anyways, here's the list I edited: Newegg.com - Once You Know, You Newegg
Old October 6th, 2008, 12:34 AM     #9 (permalink)
SoMuchAnime-SoLittleTime
EXreaction's Avatar
What is with those speakers?
If you plan on doing any gaming/movie watching you will hate 2.1. Spend $50 more or something and get a nice little 5.1 setup.
My photography: Flickr
Lithium Studios - phpBB3, PHP, and Web Development
Old October 6th, 2008, 08:51 AM     #10 (permalink)
Super Duper Member
pullmyfoot's Avatar
Well, it depends on you. But if you were going to get speakers, I would opt for a good set of 2.1s than a crappy set of 5.1s. Unless you start to cross the $100 to $150 range. Any more than $150 and I would chuck in a sound card too to make the most of my speakers. Besides, for most of the computer setups Ive seen, its going to be hard to find a place for the extra 2 speakers behind if its just a regular desk.
***I Have $1500 To Build A New Custom PC !! Please Help Me Out...¿*** grillman6000 General Tech Discussion 51 February 7th, 2006 11:12 AM
2 monitor,2 keyboard and 2 mouse in One PC marie_selle General Tech Discussion 19 July 20th, 2004 09:25 AM
Two computers on one monitor, mouse, and keyboard? unknown9 General Tech Discussion 12 June 11th, 2004 12:08 PM
Monitor, Mouse, Keyboard MMock General Tech Discussion 11 July 19th, 2002 11:32 AM
Multiple computers connected to the same monitor/keyboard/mouse - how? newbie~wan General Tech Discussion 5 December 19th, 2001 09:40 PM
Is It Just Me? (3063)
Health Care Rationing (11)
Delete an OS (16)
Nvidia GTX 260 problem (9)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
Share an Easy Way to Convert DVD and .. (0)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (38)
Dynex DX E-402 (3)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
