My New Project (Long Term)
Currently Active Users: 2554
Discussions: 200,516, Posts: 2,374,472, Members: 245,841
Old October 9th, 2008, 09:27 PM     #21 (permalink)
No, the one I just built. From my other post. I got the motherboard in today and put it together. It POSTs then says something about the HDD is detected then that the Chassis is infringed or invaded and then something about USB Over something. Then shuts down.
SirRob is offline   Reply With Quote
Old October 9th, 2008, 09:33 PM     #22 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Might want to start a new thread. Lots more people will actually look at it.
And might do a bench test.
Remove the motherboard from your case. Set it on something non conductive (cardboard works fine) and plug in just the bare essentials.
-CPU and heatsink
-1 stick of ram
-video
-power supply
You can power it up by touching the on/off pins with a screwdriver, or something else metal. See if it posts then. If it does, start adding parts till you find the culprit.
But you should start a new thread.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old October 9th, 2008, 09:43 PM     #23 (permalink)
Started the new thread....
Anyway back to this. So yeah the Water Cooling is gonna take up a good $600 easy. Now though, since the LAST thing I'll be getting is the GPUs (in hopes that by the time I am going to purchase them the price will have come down a bit). So is there a thing I have to plug into the motherboard or is it it's own system. i.e do I have to start it separate from the computer? Is there any motherboard requirements? I'm thinking the way to go is the X58 chipset though.
Old October 9th, 2008, 10:04 PM     #24 (permalink)
\m/(°-°)\m/
Well that's what I'm saying. It doesn't have to take up $600. You can make a good setup for $250-$300. If you want to save money, get a big Rad, and then you won't need 2 loops IMO.
As far as mobo requirements, the only thing you need to check, is the CPU block, to make sure it comes with the mounting hardware for your socket. Other then that, no there is no Mobo requirements.
Old October 9th, 2008, 10:32 PM     #25 (permalink)
Well I only said the 2 loop because I thought it was 2 loops same pump. But I think the 1 big loop would be more economical. I'd just get much better equipment and better coolant.
Old October 9th, 2008, 11:13 PM     #26 (permalink)
\m/(°-°)\m/
alright then.
Use the DDC pump, with the acrylic top I linked to before. Get your blocks..I prefer EK for GPU's.
For CPU's, especially Quads, I'd get the Fuzion V2. Now the Quad nozzle only helps by a couple degrees, so that's up to you.
For a Rad, you can get the big 480 if you want. Or if space is a factor, then you could maybe get away with a triple rad. But your gonna need high CFM fans if you go with the triple. The 480 yo could probably get away with medium speed fans, and have decent temps still.
Old October 10th, 2008, 01:03 AM     #27 (permalink)
Now is there any unconventional methods to making the water colder so it can help with the cooling...such as me keeping it near the window...open....where its about -5c?
(Btw fixed the problem with the other one. SOOOOO many things were out of place.)
Old October 10th, 2008, 01:49 AM     #28 (permalink)
I have had my Rad out side in the winter and when benching hard I have put the rad in a bucket of ice .
If you want to go extreem you can get rid of the rad in your loop and replace it with a water chiller ( guts from a AC put into a cooler and your water pumps though it )
E8400 8.5x500=4250mhz 1.38v 24/7 ( 4.7-4.9ghz for benchs ) /Evga 780i
OCZ PC-6400 5-4-4-15 800mhz 1.9v / Corsair 620hx / 8800gt @ 740/1800/1000 24/7
||Console|| is offline   Reply With Quote
Old October 10th, 2008, 08:30 AM     #29 (permalink)
\m/(°-°)\m/
Yeah I've heard of people using buckets of ice water before. And I've even seen people mount the rad to an outside widow ledge.
If your going for extreme, look into a chiller like console said, or TEC unit. They are pricey, but your load temps are gonna be in the negatives.
For most of us though, water will cool down well enough.
Recomendations for long term storage of a Inkjet printer videobruce Graphic Design and Digital Photography 2 March 5th, 2008 09:51 AM
Sega Doubts Wii's long-term potential SoloCamo General Gaming Discussion 14 June 26th, 2007 10:15 AM
Comp freezes during long term processes RogueLemming General Tech Discussion 6 July 1st, 2004 03:57 PM
Are there cases for long-term HD storage? MikeGn General Tech Discussion 43 January 29th, 2004 07:39 PM
US to Discontinue Long-Term, Low-Yield Investment in Nation's Youth Theophylact IMO Community 1 September 26th, 2003 10:37 PM
Is It Just Me? (1649)
windows 7 retail and rtm (5)
HELP!!! What do you think of this s.. (24)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
slaving laptop drive (7)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
nvidia geforce 9500GT 1gig DDR2 (0)
HELP!!! What do you think of this sys.. (24)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
