What media player will play .avi?  | | |
May 15th, 2002, 11:07 PM
What media player will play .avi? Windows media player says it doesn't support it. Anybody?  |
May 15th, 2002, 11:08 PM
| | dword to your moms
It is probably a DivX file....try Global Divx player http://www.divxity.com/
There are many others too....you will probably need to isntall the DivX codecs. |
May 15th, 2002, 11:10 PM
| | Goverment property now
May 15th, 2002, 11:13 PM
XP Pro, I think it's 8.0  |
May 16th, 2002, 12:57 AM
| | dword to your moms
Media Player wont support all of the DivX files though, it will do some, but not all. |
May 16th, 2002, 01:31 AM
| | OH NO!
May 16th, 2002, 04:05 AM
Yeah, avi is a very loose file format, an avi file can be encoded in any number of different codecs, you need to find out which codec it's in. If it is in divX then installing the divX codecs from www.divx.com should let you play it in Windows Media Player (although a specialised divX player will be more efficient and possibly support more formats) |
May 16th, 2002, 06:08 AM
| | nuisance since 1968
Good God!!! Do not get the Realplayer if you can help it. It's absolutely horrid.
All versions of Windows Media Player should play most any video file as long as you got the right codecs installed. |
May 16th, 2002, 06:46 AM
| | Banned
I hate Real Player and i hate Quicktime but i still have them on my comp, the problem is that on lot of sites you can only view the movies in Quicktime, and i have lots of DragonballZ episodes in RM format, although i believe it also works on Media Player. |
May 16th, 2002, 06:49 AM
Where do I get the right codecs?  |
