Vga connection to monitor
Currently Active Users: 1450
Discussions: 195,859, Posts: 2,328,010, Members: 241,383
Old November 22nd, 2008, 08:29 PM   Digg it!   #1 (permalink)
I have 22 inch lcd hdtv monitor and it came with (i'm assuming) a cheap vga to vga cable. I use this cable to connect my laptop to this monitor.
The problem I'm having is that the connection seems to be bad because the picture tends to shake and wavy lines go up the screen which is very annoying and makes me dizzy. Some days are worse than others but even on the best days you can still make out the fuzzyness and screen shaking. Does anyone know why this is happening? Is it because I'm using a cheap vga cable and if I buy another one, would it solve this? I'm not 100% sure if it's simply interference, although it may be the case. Any help would be appreciated
rbk44 is offline   Reply With Quote
Old November 23rd, 2008, 02:17 PM     #2 (permalink)
BipolarBill's Avatar
It may be the cable, but try using different refresh rates for this monitor. You should be using 60Hz.
Also, find out what the native resolution is for the display and use that setting.
There is no real difference in performance between VGA and DVI, so don't go there.
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old November 23rd, 2008, 02:34 PM     #3 (permalink)
I am using the native resolution (1680x1050) and it has always been set to 60Hz so those are not the problem. The only explanation I can think of is the cheap vga cable but does anyone know if the stock cables that come with monitors are really that cheap and don't provide all the interference blocking? Or anyone have any other ideas?
More info - the wavy lines and shaking seems worse on sites that have a dark gray background (ex. espn.com where the sides are that dark color the screen seems the shake more) it's very strange...
VGA MONITOR WITH DVI CARD Foodman Graphics Cards and Displays 0 August 11th, 2008 08:56 AM
How do you know if your VGA monitor going out drjekel_mrhyde Graphics Cards and Displays 0 June 6th, 2007 06:20 PM
Looking For VGA Cable Connection (With Pics!) bmons Graphics Cards and Displays 6 December 13th, 2004 12:05 AM
Vga Mirror Monitor Problem futronix Graphics Cards and Displays 0 November 4th, 2004 10:52 PM
Replacement vga monitor cable. golfcart General Tech Discussion 12 November 16th, 2002 10:13 PM
Is It Just Me? (1447)
Palin Resigning as Governor (45)
Budget PC Build, first time - Need .. (14)
[F@H SPAM 28 JUN 09] Today's the da.. (138)
Looking for Some good PC games. (9)
build advice (20)
Worth upgrading GFX card? (36)
You guys might like this one (22)
Crap, my graphics have gone to hell (17)
4gb RAM (7)
Is this a decent gaming system??? (25)
Gigabyte 770 vs 790GX (cant decide) (8)
Need Technical Expierience (77)
need a laptop (5)
build advice (20)
Desktop Computer on Laptop Screen (1)
Windows 7 Beta won't install (6)
[F@H SPAM 28 JUN 09] Today's the day... (138)
Gaming Laptop (2)
[Seriously need help] External hard d.. (0)
Not enough RAM... (1)
wifes laptop (1)
Apple no longer using nVidia? (0)
internet connection is breaking (10)
please help (1)
What salary can I expect once I gradu.. (0)
Windows Product Key (5)
Weird Battlefield 2 errors (3)
ps3 connection- no video signal (1)
firefox 3.5 is slow to start (10)
Apple iPhone 3G S 32GB Unlocked (0)
Explorer page shuts down...HELP.. (0)
video card (2)
need a laptop (5)
6 Quad/S SeriesMotherboard (0)
