Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 121 to 139 of 139
  1. #121
    Feb 2007
    Springfield
    13,485
    5
    No, that was for 3dmark 06. This uses all of the programs.
    I'll update when I get home. I doubt it would be easy to do via phone.
    FAQ's ~ Team Stats
    My PC
  2. #122
    Ultimate Member cksboy15's Avatar
    Nov 2008
    Columbus, Ohio, Unit
    1,426
    probably not. Well when I get 06 and the other program downloaded and 05 to work (seeing that it still won't) I post results.
  3. #123
    I Haz Catputer JLK03F150's Avatar
    GA
    5,494
    You might need to download & run the unified hotfix for 3dMark and PCMark, cks.
    |MG| 3DMark And PCMark Unified Hotfix October 2007
  4. #124
    Banned by everybody Ultima's Avatar
    5,076
    I will be submitting a new score tommorrow btw, the pcmark score is as triplecore @ 2.8 instead of like the rest of the scores as quadcore @ 3.6.
    That should just give me 1st place in single card list.
    2 x Opteron 4280 2.8Ghz, Asus KCMA-D8, 32GB DDR3 1600, Asus 6950 DCII 1GB 2 x M4 64GB SATA600, Caviar Black 640GB, Seagate 1TB, 27"syncmaster
  5. #125
    Feb 2007
    Springfield
    13,485
    5
    Nice. Good luck with the benching.
    FAQ's ~ Team Stats
    My PC
  6. #126
    GA
    5,494
    Quote Originally Posted by Ultima View Post
    That's gonna be a nice jump.
    I had to really push my dual core to get my score. That reminds me, I haven't tried overclocking with my new RAM yet. My PC6400 could only get to 450MHz & that was a bit squirrelly. I have some PC8000 now.
  7. #127
    Feb 2007
    Springfield
    13,485
    5
    This was me playing with my ram the other day.
    CPU-Z Validator 3.0
    I can bench at 640Mhz (1240 effective) and that's DDR2 800.
    FAQ's ~ Team Stats
    My PC
  8. #128
    GA
    5,494
    Nice! What kinda volts are you running to get there? I hope you have a fan on the RAM too.
    My old RAM is G.Skill PC6400 HZ, which is the D9GMH stuff. For some odd reason it won't work at 5-5-5 at all, which is what I need to get past DDR900. All I can run is cas4 with this RAM.
  9. #129
    Nov 2008
    1,426
    Thanks for the tip JLK
  10. #130
    Feb 2007
    Springfield
    13,485
    5
    Quote Originally Posted by JLK03F150 View Post
    That is at something like 2.35v I believe. These are D9's too.
    Oh, have you tried the freezer trick? That's what I did before I ran that little test. I actually read that if you bake your ram at 400 for 8 min, then let it cool, then put them in the freezer over night it can bring back some ram from the dead.
    Which that's what that set went through. I ran a test for a good 24hours, and it was stable. (between folding, prime, games, the works) but then got a BSOD, so I pulled them out.(ended up being a driver thing though)
    I'll quit rambling now. But you may try sticking them in the freezer overnight.
    FAQ's ~ Team Stats
    My PC
  11. #131
    GA
    5,494
    My HZs still work, they were just limiting my oc because I can't run them 5-5-5. I know I could get a lot farther if it would let me loosen the timings, but they only work at 4-4-4. I also know part of the problem is my pita asus mobo.
    I forgot that I got to DDR920....
    http://i190.photobucket.com/albums/z...0mhz_fww09.jpg
  12. #132
    Nov 2008
    1,426
    I tried that before and it actually helped my last systems memory OC better which suprised me.
  13. #133
    5,076
    I think it is time for me to also start playing with the videocard.
    All those scores are with just the cpu overclocked, I haven't touched the 4870 yet.
    I'll try and get some nice scores tonight when I have time.
  14. #134
    Feb 2007
    Springfield
    13,485
    5
    So do you want me to wait on the update then?
    If you got more scores coming, I might as well I guess.
    Let's see what she has.
    Full power Mr. Scott! [/kirk]
    FAQ's ~ Team Stats
    My PC
  15. #135
    5,076
    Aye aye Mr. Scott.
    Pulling away @ 3.6Ghz quadcore, new passmark score is:
    1675 points, making my new total 38580, just falling short of 1st place.
    I dunno when I can do some more testing with the videocard overclocked as well, so might as well put the score up.
    I'll post updates of the new scores later, in 1 post so not too much trouble.
  16. #136
    Feb 2007
    Springfield
    13,485
    5
    Updated and gave Ultima his crown.
    Congrats sir.
    FAQ's ~ Team Stats
    My PC
  17. #137
    5,076
    well thank you my good man.
    I'll be testing now to see how much improvement I get when overclocking the card and running cpu at default.
    If the score improves enough, I will run it @ 3.6Ghz as well.
  18. #138
    Feb 2007
    Springfield
    13,485
    5
    FAQ's ~ Team Stats
    My PC
  19. #139
    Feb 2009
    Spalding, UK
    257
    here is my 3dmark05 score
    20896
    ORB - Compare
    here is my 3dmark06 score
    16796
    ORB - Compare
    and my passmark score is in the attachement.
    1419.5
    my system specs:
    q6600 @ 3.19ghz
    evga SSC gtx260 ("Core 216" 65nm architecture) @ stock
    4gb 800mhz ram
    windows xp home edition 32bit
    Attached Thumbnails Attached Thumbnails *TechIMO's Top 30 PCs*-passmark-7.jpg   *TechIMO's Top 30 PCs*-3dmark-scores.jpg
What planet do we live on?
  1. Techimo's IP address???
    By Keymaker in forum Suggestion Box
    Last Post: October 15th, 2007, 06:39 AM
  2. gaming PCs vs. great normal PCs w/ great cards
    By gamer_guy in forum General Tech Discussion
    Last Post: December 18th, 2004, 06:06 PM
  3. TechIMO's Bandwidth
    By Nightfire in forum IMO Community
    Last Post: September 10th, 2004, 10:08 AM
  4. FS: 4mega pixels, LCD monitor, PCS wireless modem, PCS digital link, scsi hard drive!
    By doneedlove in forum Traders Forum: Buy, Sell, Trade
    Last Post: May 4th, 2003, 05:14 PM
  5. TechIMO's origins
    By PostCode in forum IMO Community
    Last Post: April 8th, 2002, 03:21 PM
