Need help building a budgeted gaming system (amateur)
Currently Active Users: 2642
Discussions: 200,520, Posts: 2,374,503, Members: 245,842
Old January 1st, 2009, 08:39 AM     #61 (permalink)
I went to cmd and typed in "ping -t 192.168.1.1"
and then it started pinging my router.
it showed this line.. one second at a time
"reply from 192.168.1.1: bytes=32 time=<1ms TTL=64
occasionaly it would have a request timed out line (every 5-15 lines)
but the thing I noticed was that EXACTLY every 60 lines ... the time would jump from <1ms to around 600-1500 ms.. just for the one line.
I'm guessing this is the spike problem that is pissing me off.
Based off google searches, I think problem is because of the incompatibility of the ralink rt2561 chipset for my adapter with Windows Vista 64-bit. It's actually a common problem.. called something like the vista 60 second lag spikes (1-3 second lag spikes every 60 seconds.
I say this because I have two other laptops. My laptop has XP. I tried this same cmd command on there... no major spikes...my dad's laptop is Windows Vista 64 bit (only difference is that his is home edition, the PC i just built has business edition) and that did not have any spikes as well.
So that means the only variable that remains is the adapter.. and based off google searches I think it's because it is incompatible with Vista 64-bit (I guess the laptop adapter is not the same chipset).
My friend has this router: Newegg.com - Rosewill RNX-G300EX IEEE 802.11b/g PCI Wireless Card Up to 54Mbps Data Rates 64/128-Bit WEP, 802.1x, WPA, WPA2, AES, TKIP with 100cm cable external 2 dBi Antenna - Wireless Adapters
He has the same problem.. however, after downloading one of the ralink drivers from these forums:
Vista Wireless Network Lag/Spikes - Page 2 - Vista Forums
http://www.tomshardware.com/forum/23...wmp54g-drivers
He was able to fix the spikes. He downloaded and installed the driver, and then ran a program called WLAN Optimizer.
WLAN Optimizer .NET
^ That is a fix for my exact problem.
However, I could not manage to install the rlink drivers. It kept saying unsuccessful or whatever when I clicked browse and specified the driver. It worked for him though, and he suggested that I get the same adapter as him.
What do you think?
kenny536 is offline   Reply With Quote
Old January 1st, 2009, 06:58 PM     #62 (permalink)
The root problem for this I think is the WLAN Autoconfig, checking for new networks every 60 seconds. to disable this i go to run > services.msc, and scroll down to WLAN Autoconfig and disable it.. but the problem is that when I disable it, I can't detect my network so I can't connect.
This Autoconfig is only in Vista so what I need to do is install XP drivers for this adapter. The problem is that linksys does not have 64 bit drivers for XP so I have to use ralink or some other driver.
I do not get any error code - the error I get when trying to install any of the Ralink Drivers is this :
Windows was unable to install your network controller
Windows could not find driver software for your device
If you know the manufacturer of your device, you can visit its website and check the support section for driver software.
The Ralink Wire Lan Card Utility/Status is just a big black X... the Ralink utility/status ONLY works when I install the Linksys driver from my cd that came with my Linksys adapter. That is the only driver I can get it to recognize and thus the only driver I can access the internet with, for this adapter at least.
Old January 3rd, 2009, 12:48 AM     #63 (permalink)
I fixed it!!! Not exactly sure how - but the important thing is that it is fixed :}. My little brother has been gaming for hours without a lag spike!
I did several things - I'm not sure what fixed it - here is what I did :
1. Installed 3rd party firmware on my router (Tomato).
2. Enabled Frame Burst and AutoBurner in the Tomato settings.
3. Replaced my Linksys adapter with a SpeedBooster adapter (same adapter, just with speedbooster).
That's it. No Ralink drivers, no anti-lag software, or anything, just used the drivers from the linksys CD. I don't know what it was, it says on the box speedboster only works with XP and 2000.. but I heard people saying they utilized their non-speedbooster router to work with their speedbooster adapter via 3rd party firmware. Maybe that's what I did (I know afterburner enables speedbooster). But I don't see how that would fix it anyway.. whatever, who cares! I'm getting excellent/very good signal with great latency!
Thanks for the help.
Old March 11th, 2009, 02:11 PM     #64 (permalink)
Hello all.
The PC is running great - but I have this error. My videocard has this error. My ASUS video card came with a software called "ASUS SmartDoctor" - I think it just monitors my video card and allows me to overclock and adjust other settings. I haven't messed with any of it.
But the other day, I get this error from SmartDoctor:
VGA's voltage is out of safe bound. Motherboard doesn't supply reliable 12.0 voltage. Contact with its manufacturer for help.
What does this mean and how do I fix it? Is my video card overheating? I am not familiar with overclocking.
Thanks.
Old March 11th, 2009, 04:06 PM     #65 (permalink)
SoMuchAnime-SoLittleTime
EXreaction's Avatar
What power supply do you have?
My photography: Flickr
Lithium Studios - phpBB3, PHP, and Web Development
Old March 11th, 2009, 06:06 PM     #66 (permalink)
Fizur2002's Avatar
you beat me to it EX
Originally Posted by pullmyfoot View Post
Aha. Well that was a waste of time I feel quite stupid now
Originally Posted by Figgey View Post
CPU: AMD 64 Pentium 4 (939 Socket)
Originally Posted by strjms72 View Post
Craysis is more better than COD 4.
Fizur2002 is offline   Reply With Quote
Old March 12th, 2009, 12:41 AM     #67 (permalink)
Okay, I think the problem is that the program is not reading my voltage accurately. I downloaded SensorViews Pro 3.2 and the +12V is stable at around 11.6V - so I don't believe there is any problem.
My PSU is a CORSAIR 650W
Hello- Complete webpage-building amateur DDDD Graphic Design and Digital Photography 13 December 1st, 2005 08:51 PM
what you think about this gaming system i'm gonna build? (Cheap gaming) CJL17 General Tech Discussion 6 May 23rd, 2005 03:25 PM
Building a Budget Gaming System Cukimunga General Tech Discussion 7 April 29th, 2005 01:15 AM
Building a LOW Budget gaming system Lateralus General Tech Discussion 31 September 27th, 2003 04:55 AM
need help with building a gaming system girlstellmelies General Tech Discussion 11 September 6th, 2002 06:53 AM
Is It Just Me? (1661)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
[F@H SPAM 11/1/09]New month . . . n.. (34)
Aero in Vista (7)
slaving laptop drive (7)
[F@H SPAM 11/08/09] Where has all the.. (2)
Which monitor should I get? (13)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
