New Build Help
Currently Active Users: 1560
Discussions: 200,506, Posts: 2,374,393, Members: 245,829
Old December 15th, 2008, 11:39 PM   Digg it!   #1 (permalink)
New Build Help
I am also building my FIRST computer and would appreciate answer to the following questions:
1. What type of case would you recommend from newegg (based upon your build list).
2. This is really a dumb question: how can I wirelessly browse the internet. I do have Linksys wireless router. Do I have to buy any hardware?
3. Another stupid question: Is this motherboard sufficient so that it can be upgraded for the next 3-4 years (upgrading RAM, video card, more hard disk space)
4. Do the drivers come with hardware or vista contains all the drivers?
5. Is it true that any 19 inch - 22 inch LCD monitor is compatible?
6. can you recommend a sound card?
7. Other than mouse keyboard, am I missing anything?
one more thing: what does MOBO mean?
Thanks, again ...appreciate any help!
Originally Posted by KarmaKiller View Post
Hi and welcome to TechIMO.
I'm just gonna make a build list. It's a lot easier for me, and I can promise you everything will work, and it'll be a great PC. For your $700 budget, I'd go with:
CPU:
E8400 is a good choice. If you wanna move up to a Quad, I would recommend the Q6600.
Motherboard:
You have a lot listed. Personally, I think your best choice is:
Newegg.com - GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
RAM:
4gigs is pretty much the standard now.
Newegg.com - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Desktop Memory
PSU:
Newegg.com - Antec Basiq BP500U 500W ATX12V Version 2.01 Active PFC Power Supply - Power Supplies
DVD:
Newegg.com - SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner - CD / DVD Burners
GPU:
I know you said you have the 8600gts, but I'm gonna save you some time and dissapointment.
Newegg.com - MSI N9800GT 512OC GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Desktop Graphics / Video Cards
Get that card. It's worlds better then the 8600gts.
OS:
Newegg.com - Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - Operating Systems
Vista is come to be a pretty decent OS. If your gaming, you want vista.
That would be a great budget build.
yoyo2yoyo is offline   Reply With Quote
Old December 15th, 2008, 11:50 PM     #2 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
What is your budget for the PC?
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old December 15th, 2008, 11:51 PM     #3 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
Post moved, please don't hijack another user's active thread.
Linus Torvalds
RicheemxX is offline   Reply With Quote
Old December 16th, 2008, 12:00 AM     #4 (permalink)
Thank you, my budget is between $700 - $900 for gaming computer.
Old December 16th, 2008, 12:16 AM     #5 (permalink)
zepper's Avatar
Lightbulb
You're checking Mechbgon's guide, right?
The Rosewill R5605 is excellent if on a budget. Solid and plenty of room for a long vid card. Has some hidey holes for cable management. Check out the Rosewill Conqueror too for a ricier box - it's identical to the Silverstone PS01. It has been on sale almost since it showed up - very like the SST KL01/02 inside.
You will need a wireless networking card to use a wireless router from a desktop machine as most don't come with them. Most laptop/notebook PCs come with them pre-installed or integrated. Get one that matches the protocol of your router and perhaps the same brand as your router if it's performance is nearly equal to any of the others. Time to check the reviews around the web.
Even I can't stand to keep a mobo that long...
Vista contains a lot of basic drivers, but you will want the latest proprietary drivers to take advantage of the extra features of new peripherals. Always check the various component's mfr's web sites for the latest versions. No sense having to install them twice. The mobo is likely to have updated drivers and/or BIOS available too - nothing ever seems to ship with the latest drivers.
Depends on what your video card supports. Many monitors support the old VGA connection as well as a digital connection. So just make sure the monitor you decide on supports the connection type your vid card has. Some monitors have strange res specs these days for wide screen monitors. Most vid cards should support these different specs. The old standards were basically the same ratio as
640x480, 800x600, 1024x768, (basically the 3,4,5 dimensions considered the "magic" rectangle supposed to be unusually pleasing to the eye) etc. Many current monitors can't support 3,4,5 except by just using a part of the screen area.
I'd wait to see if the integrated sound is adequate. That's getting better all the time. I doubt that many go with separate sound cards these days except perhaps for really serious gamers or audio production types.
mobo is shorthand for motherboard (you know, like mofo is short for _______ ___ . ;-)
.bh.
zepper is online now   Reply With Quote
Old December 16th, 2008, 12:18 AM     #6 (permalink)
\m/(°-°)\m/
Hmm.. that's doable. I assume this is mainly a gaming machine?
My suggestions:
Newegg.com - Intel Core 2 Duo E7200 Wolfdale 2.53GHz 3MB L2 Cache LGA 775 65W Dual-Core Processor - Processors - Desktops
$120
Newegg.com - ASUS P5Q SE PLUS LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
$96 ($81 after MIR)
Newegg.com - OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
$47 ($18..yes $18 for 4gigs of RAM after MIR)
Newegg.com - OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V SLI Ready Active PFC Power Supply - Power Supplies
$75 ($40 after MIR)
Newegg.com - SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
$159 ($145 after MIR)
Newegg.com - Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
$50
$100
Newegg.com - COOLER MASTER Centurion 590 RC-590-KKN1-GP Black SECC / ABS ATX Mid Tower Computer Case - Computer Cases
$60 (free shipping)
Total: $708 without rebates
With MIR factored in: $574 (kind of impressed with that myself) lol
Leave you enough for one of these:
Newegg.com - Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor 300 cd/m2 2500:1 - LCD Monitors
$169. That is 22" of pure WIN! These are great monitors.
What do ya think?
EDIT:
Nice post Zepper!
Old December 16th, 2008, 12:37 AM     #7 (permalink)
Wow this is awesome! Thanks Zepper and KarmaKiller :-)
Can you suggest me a quad core processor (CPU) or is the above mentioned processor powerful for the next 2 years and can be upgraded later?
I searched the Rosewill Conqueror at newegg. It comes with 500w power supply. Could you paste the correct links? thanks.
Newegg.com - Rosewill Conqueror WBK Triple 120mm Fans Steel ATX Mid tower Computer Case with Side Panel - Computer Cases
Newegg.com - Rosewill Conqueror RPS-01-WB500P Triple 120mm Fans Steel ATX Mid tower Computer Case with 500W Power Supply - Computer Cases
which one?
Also, can you suggest a much larger hard drive. > 600 gb hard drive
Old December 16th, 2008, 12:52 AM     #8 (permalink)
\m/(°-°)\m/
Cheapest Quad on egg:
Newegg.com - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Processors - Desktops
Same one I run. They solid CPUs.
Newegg.com - Intel Core2 Quad Q9400 2.66GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor - Processors - Desktops
That would be the next Quad (as far as price goes) that I would get.
And on the upgraded later. In theory, any CPU you pick up can most likely be upgraded. BUT, is it always worth the price is a whole other question. Intel already has the newer socket out (1366) and are already in the phase of switching over to that socket. Now I'm not saying this PC is gonna be slow or anything. But the chances of the upgrade 2 years from now actually being worth it are pretty slim.
As far as the HDD, this is my normal suggestion:
Newegg.com - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
I just picked one of these up myself, and they are fast. If you want more then that, then I would suggest:
Newegg.com - Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
But they aren't as fast as the 640gb drives.
Old December 16th, 2008, 01:01 AM     #9 (permalink)
THANK YOU x3!
One last request: I am still confused when it comes to case:
which one?
Also, do I have to wear some kind of "static grounded wire thingy"
Anything, else I am missing before going for the purchase?
Old December 16th, 2008, 02:31 AM     #10 (permalink)
Out of those, I would go with the Rosewill Conqueror RPS-01-WB500P Triple 120mm Fans Steel ATX Mid tower Computer Case with 500W Power Supply - Retail. At $10 more than the other two (also free shipping), the additional power supply should be worth it.
techi46 is offline   Reply With Quote
New Computer Build HELP! (Please look over new build)??? roosta21 General Tech Discussion 30 June 29th, 2008 10:08 PM
To build or what to build lol Southern Belle Motherboards 55 September 5th, 2007 05:23 AM
help with new build lukesparksoff Motherboards 7 September 28th, 2005 06:54 PM
My first build Sysroot General Tech Discussion 14 November 13th, 2004 01:33 AM
to build or not to build, that is the question... cyphen General Tech Discussion 11 April 5th, 2004 02:53 AM
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
