Results 1 to 4 of 4
    Ordained Mommy NeoStarO1's Avatar
    Big Sky Country
    5,823
    Firefox Problems
    Hey Gang,
    Using firefox on Toshiba Laptop using Windows Vista 32bit edition.
    Problem (s)
    Before it was not working at all, completely cleaned system of firefox and cleaned the registry of all traces, downloaded firefox and now these are the same problems showing up.
    Any ideas?
    1. When opening a website (any) it ask to download a file, I changed the options to set it to open with firefox. It goes through the process then opens.
    2. Whenever you click on a link it automatically opens that link in a new tab and want it to open in the same tab.
    3. whenever you click on a link it automatically opens up a bunch of pop up ads. (popup blockers are set to on and it still does it anyways.)
    I'll be back in tommorrow to try what you all suggest and keep you updated.
    Blessings,
    Karin
    Edit: BTW I am not that familar with firefox just so that ya'll know.
    ph34r t3h g04t Whir's Avatar
    Kingsford, MI
    29,343
    7
    Sounds like you have some malware, Karin. Run Spybot or Ad-Aware on that puppy.
    Big Sky Country
    5,823
    yeah i think you might be right. I decided to do a reformat. his computer really needed to be tweaked anywaays, but i want this thread to keep going just in case i run into the same problems again. couple other people have already tried to fix it at no avail and i discovered there were more problems than orignally started out with. Get the people talking and you'll find out what happens.
    So right now its finishing up a reformat and then customize and tweak his system. not only that, this system also gets connected by wifi at our work and theres beena virsu going around. we already lsot one computer due to this so I thought it would be better to start from scratch. so that is what im doing right now.
    Jan 2003
    Outside the box
    8,489
    4
    Well not that it applies now, but I always create a new profile and/or run firefox in safe mode when I need to troubleshoot any issues. I know you said you removed FF and deleted it from the registry but occasionally something gets overlooked.
  1. Browser Problems - IE/Firefox/Opera
    By JetsMets77 in forum Technical Support
    Last Post: July 5th, 2007, 11:14 PM
  2. Java problems in both IE6 and Firefox
    By rallen88 in forum Networking and Internet
    Last Post: June 19th, 2006, 06:04 PM
  3. Search Engines For Firefox 1.5 Problems
    By lablkilz699 in forum General Tech Discussion
    Last Post: November 30th, 2005, 10:45 PM
  4. Firefox problems
    By Poindexta in forum General Tech Discussion
    Last Post: August 9th, 2005, 10:28 PM
  5. Problems loading pics etc after Firefox update
    By Anarchitect in forum Technical Support
    Last Post: May 15th, 2005, 06:51 PM
