Finishing off my first built computer, need help please.
Currently Active Users: 1618
Discussions: 200,509, Posts: 2,374,406, Members: 245,832
Old January 10th, 2009, 11:18 AM     #11 (permalink)
Super Duper Member
pullmyfoot's Avatar
Yeah. You should hit 3ghz with that thing easy
pullmyfoot is online now   Reply With Quote
Old January 10th, 2009, 12:33 PM     #12 (permalink)
You're probably right, but before I mess with that I am going to get that 9800GT and get vista 64 so I can actually use my 4 gigs. I want some gaming goodness ready for Empire: Total War in March .
johnross2007 is offline   Reply With Quote
Old January 10th, 2009, 12:53 PM     #13 (permalink)
Super Duper Member
pullmyfoot's Avatar
Thats the game I have been looking forward to as well If I get only one game this year, its going to be that . I think you might need to get a faster graphics card though. I doubt you will be able to put the game on very high settings given how massive and demanding the game looks. I would look to get at least a 9800GTX+. Even I'm worried about my HD4850 playing that game (which is about equivalent to the 9800GTX+). But if you can live with med (maybe even low-med) settings then it should be fine I guess. But I dunno. We will have to wait for it to come out to see.
Old January 10th, 2009, 01:11 PM     #14 (permalink)
awww you're scarin' me. I know the minimum specs are really low, recommended haven't been released yet. From what I here the Total War guys tend to be very efficient with their graphics. Hmm...... well I might just do that. Maybe I'll find a deal.
edit: Now that I think about it, by March the GPU prices should be much more favorable considering the new GTX295 is out to push down prices, and I hear a 300 series is coming soon. Maybe I will be conquering the world with GTX260!!!!
Old January 10th, 2009, 11:20 PM     #15 (permalink)
I finished off my ordering, and the rest should be arriving on Tuesday. My set up looks like:
Case - Antec 300
CPU - Core 2 Duo E8400
Motherboard - Newegg.com - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
RAM - GSkill 4G DDR2 800
PSU - Corsair 750W
Graphics card - Sapphire Radeon 4850 512MB (apparently this dropped to 10 bucks after I purchase it -_-)
HDD - Western Digital 500G 7200RPM SATA 3.0Gb/s
OS - Windows Vista 64 bit home premium
This will be fun putting it all together. Lets just hope there are no dead pieces.
And to overclocking, I'll give it a shot. If the performance is significantly better, I'll do it. About OCing though, should I get a new CPU fan and add any other case fans? I've been told the Intel cpu fan isn't that great for OCing.
iddqd is offline   Reply With Quote
Old January 10th, 2009, 11:44 PM     #16 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Yes..you want to upgrade your cooling. The cooler the chip runs, the better OC you can get.
What's you budget, I can recommend good coolers.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old January 10th, 2009, 11:54 PM     #17 (permalink)
I'd say 60 USD max for the cooler. Only if it's worth it that is. :-p I will take everything you say into consideration KarmaKiller (this is Edward91 that PMed you randomily :P).
Old January 12th, 2009, 07:40 PM     #19 (permalink)
I'll check those out, thanks a lot. A question about
the fans: would it be viable for me to go ahead and
put my system together (with stock cooler)to see if everything runs fine,
then apply the new CPU fan? Or is it a real pain to remove
the motherboard/install the new fan?
Sorry for the odd looking post, on my iPod touch atm. :-/
Old January 12th, 2009, 07:44 PM     #20 (permalink)
Well the biggest pain will be installing that stock heatsink/fan.
One thing that might give you trouble is removing the thermal paste (or whatever its called) when you go to install the new HSF. You will need to get rid of all of the old paste before applying the new paste. Also, for the thermal paste you should try, I think it is called Arctic Silver 7.
edit: to get the paste off of my CPU I used isopropyl alcohol (I think it was called that at least). It evaporates very fast so it can be used on sensitive computer components. I also used coffee filters, I think because they don't have lint or something. I basically read a guide on the internet and am merely telling you what I remember. I would suggest googling it.
Finishing new computer build- need hd, gpu, and optical drive theicfire General Tech Discussion 0 December 5th, 2008 12:20 AM
Built My New Computer RetroEvolute General Tech Discussion 5 December 2nd, 2007 07:47 AM
Best built computer Palamoon General Tech Discussion 7 July 18th, 2007 05:26 AM
Built my first computer... CRS6785 General Tech Discussion 2 April 6th, 2004 09:51 PM
self-built computer is acting up, HELP! Elvaandragoon Technical Support 33 November 1st, 2003 06:12 PM
Is It Just Me? (1635)
Review My Build (6)
Assosiations (21496)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
boot from CD-ROM in chipset via P4M80.. (0)
Review My Build (6)
windows 7 retail and rtm (1)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
