Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
    how to make small picture big without lose quality?
    is there such program exist?
    Dec 2008
    East Chamunga
    2,364
    There are many issues regarding this: What is the source file type? If it is a Jpeg, or Gif, it is likely very compressed, and will not lend itself to much enlargement. A Tiff or Raw file on the other hand can usually be worked with... The application I use is IrfanView - Official Homepage - one of the most popular viewers worldwide It uses a Lanczos Filter to interpolate the resizing... There are other apps out there as well... Gimp comes to mind.
    ◄ it is what it is ►
    Quote Originally Posted by bigBonehead View Post
    oh i see.
    well can you do one for me? i love this side boob.... i want to put it on my wallpaper size 1280x1024 on 17 inch lcd. mabinogi 2 - Google Image Search
    it is too small that wont cover my whole screen.... and if i stretch it... it look stretch it.... it look stretch up and blurry.
    can you make one and send it to me? the one with side boob, blonde girl. also i do want the other one too.... but make the side boob blonde girl priorty.
    let me know if you willing to do it. it is your choice.... the power of you.
    so far this is the biggest i found
    http://images.mmosite.com/feature/ne...binogi2_01.jpg
    http://images.mmosite.com/feature/ne...binogi2_02.jpg
    but still i need 1280x1024 without looking stretch up
    Ultimate Member BipolarBill's Avatar
    May 2002
    Northern New Jersey
    2,724
    So use IrfanView to increase the size.
    Image > Resize/Resample.
    MCSE, MCP and nut job
    Quote Originally Posted by BipolarBill View Post
    ok cool i can make it to 1280x1024 but the quality is a bit blurry. is there such program that can make 100% no loss quality?
    West Haven, Utah
    38,836
    How about using Google to search just for that size of graphic file. See if there's anything here that you like:
    mabinogi 2 wallpaper imagesize:1280x1024 - Google Image Search
    ...Don't Mind Me... ShyguyXPC's Avatar
    USA
    19,335
    Quote Originally Posted by anonymous7 View Post
    not going to happen. when the image is downsized from original resolution if larger, it loses "parts" of the image, and thus is permanently lower, the methods mentioned above for the programs linked to use filters or other equations & Formula's in software to approximate & fill in the "holes" when enlarged again with what it thinks the proper pixels/colors/shades should be, but will never be 100% no loss again. unless as howste mentioned, doing a search for the same image in a larger "original" resolution.
    Prof. of DooGlian Studies MegalosSkylaki's Avatar
    Nr. GroundZero NYC
    10,286
    Wink Perhaps this might be of some help.
    FIRST TEN YEARS ANNIVERSARY HONOR ROLL
    this April 18th, 2014 and will be Officially Celebrated That Day! SEE http://www.techimo.com/forum/imo-com...ml#post1070600
    West Haven, Utah
    38,836
    You can always combine several images at their original resolution, or add a border around the graphic with a bunch of smaller images...
    USA
    19,335
    Quote Originally Posted by MegalosSkylaki View Post
    same basic info in that thread also already stated in this one.
    Nr. GroundZero NYC
    10,286
    Euclid, Dept.
    Which means that same basic info \stated in this one is already stated in that one.
    Actually, not entirely so.....
    DOOGFURD
    Jan 2003
    Milwaukee, WI
    7,657
    mabinogi2 - TechIMO Photo Gallery
    Is this what your attempting to do?
    Quote Originally Posted by JPMiller View Post
    not actually but thats a good idea... have all them together.
    i see no quality loss there and it is 1280x1024. but one thing.... is that fade black have to be there?
  15. #15
    Jan 2003
    Milwaukee, WI
    7,657
    No, but it was already mostly there and it helped fill in the area the windows toolbar would be ... I'll try reworking it...
    OK here.... round 2
  16. #16
    Go back to sleep Creatures's Avatar
    Jul 2002
    Switzerland
    9,283
    i really like this idea: The Sect of Homokaasu - The Rasterbator but it probably isnt what you are looking for
    Creatures
    EOS 5DS R | 16-35mm f/4L IS | 24-70mm f/2.8L II | 85mm f/1.2L II
    100-400mm f/4.5-5.6L IS II | 100mm f/2.8L Macro IS | MP-E 65mm f/2.8 1-5x
  17. #17
    Quote Originally Posted by Creatures View Post
    Creatures
    hmm no idea ill read it later.
    OK here.... round 2
    ok thats good enough. her white pants is see longer down now. ill keep this one. thanks for the help.
    oh one more thing.... is it posible to remove that 4 circles? or it have to be there to fill in?
  18. #18
    USA
    19,335
    hows this? Mabinogi_final_post 2 - TechIMO Photo Gallery
    all I did was save the image JP did, load it in GIMP 2, and then using the color selecting tool, sample some of the black/dark area around the circles, then using the paint brush tool, one of the larger circle shape ones, scaled up the size of the brush & then clicked on areas over the circles, eliminating the circles with the sampled similar surrounding colors.
    saved it, uploaded & here it is.
    GIMP's one of the programs I like to use outside of Photoshop for occasional 2D image editing...
    with a little practice & basic knowledge you can do some impressive work in programs like that... take this for example...
    Original image edited & rendered in 720 HD res (using Carrara 6, a full 3D graphics/Animation suite), edited the original model a little here & there, rendered it in a 2D JPEG file.
    Then loaded that image into GIMP 2 and with some of the filters & other features turned that same image into this (using Multiple lens flares & some motion blur, is all I did for this)
    latest program I'm tinkering with and thinking of investing some money into to help out with Carrara 6 (and when I can upgrade to version 7 Pro), is Vue 7 Infinite for making custom background land/spacescapes for use as backdrops in Carrara, even buying some of the modules for the free version of Vue 7 to allow 3D model imports and custom resolutions as well as remove the e-on software/vue 7 watermarks.
    but back on topic, just download & install latest versions of Irfanview, GIMP2 and play around with them, see what you can learn & come up with.
    between those, photoshop & Carrara 6 I've made myself probably a dozen or more custom desktops/images for my own personal use & to share with friends.
    best thing of all Is I'm far from having an intermediate level of experience using these 2D image editing apps.
  19. #19
    Jan 2003
    Milwaukee, WI
    7,657
  20. #20
    USA
    19,335
    took what out?
  1. Trouble with my DVR picture quality.
    By Rayz in forum PC Hardware
    Last Post: September 12th, 2009, 04:08 AM
  2. size of picture to print 4x7 quality
    By I2n0ld in forum Web Design, Development, Graphics, Photography
    Last Post: February 11th, 2006, 04:48 PM
  3. Small red cross where picture should be
    By derek makinson in forum Applications and Operating Systems
    Last Post: February 11th, 2006, 10:42 AM
  4. why the terrible picture quality ?
    By rh71 in forum IMO Community
    Last Post: July 27th, 2005, 12:23 PM
  5. Replies: 4
    Last Post: January 18th, 2002, 10:39 PM
