Results 1 to 5 of 5
    Banned by everybody Ultima's Avatar
    5,077
    "system" hogging all cpu cycles
    Hey guys,
    on my older rig, the X2 3800, from time to time, just out of nowhere, it starts reacting real slowlike and when I open up task manager to look at the running processess, I see "system" hogging like 80% cpu power, while "system idle process" takes up the rest.
    What is this "system"?? Why can't I end it?? it is frigging annoying, cause I can't even burn a dvd cause the system won't respond.
    Thanks for any help.
    Ultima
    2 x Opteron 4280 2.8Ghz, Asus KCMA-D8, 32GB DDR3 1600, Asus 6950 DCII 1GB 2 x M4 64GB SATA600, Caviar Black 640GB, Seagate 1TB, 27"syncmaster
    Dallas, TX
    12,375
    SYSTEM:
    Windows NT4/2000/XP/2003 only. A collective name for all operating system kernel threads.
    Recommendation :
    The Operating System !! Leave alone.
    Task List Programs - AnswersThatWork's famous Database of Processes, Windows Startups, Windows XP Services, Windows Vista Services, Process Library
    Oct 2003
    Canada [Maritimes]
    1,260
    may be run chkdsk/r for errors on your hard drive
    start>run>cmd>chkdsk/r
    5,077
    I ran checkdisk and the array is fine, no errors found.
    But still, from time to time, "system" comes along and takes up half my cpu power.
    Thanks to you guys I now know what it is, but what can I do when it happens?? I mean, it usually ends in me having to restart the pc, cause it won't respond to anything anymore, not even after 10 minutes.
    It happens during the stupidest things, like this morning, I plugged in my usb stick and set to copy an avi file to it....BANG!! there it hangs.
    South Jersey
    11,368
    Ultima:
    You need this: Process Explorer
    You can tray it and it will tell you exactly where the problem is.
  1. Answer to "System Volume Information access denied" question, and also system restore
    By Jüš† ä gü¥ in forum Applications and Operating Systems
    Last Post: September 26th, 2010, 08:12 AM
  2. "System failed CPU test"?/CPU multiplier
    By TuEKiD in forum Processors, Memory, and Overclocking
    Last Post: May 5th, 2006, 11:13 PM
  3. How do I disable the "power", "sleep", and "wake" buttons.
    By ShawnD1 in forum General Tech Discussion
    Last Post: January 30th, 2004, 11:50 AM
  4. Replies: 3
    Last Post: November 23rd, 2002, 03:06 AM
  5. Remember the "Worm", "Cave", or "Ribbon" games?
    By SickPup404 in forum IMO Community
    Last Post: July 10th, 2002, 07:02 PM
