WinXp Scandisk
Currently Active Users: 1491
Discussions: 200,990, Posts: 2,379,860, Members: 246,356
Old May 29th, 2002, 03:35 AM   Digg it!   #1 (permalink)
MMock's Avatar
WinXp Scandisk
Ok guys every time I schedule a scandisk and reboot my system halts after scandisk has completed. And then I force my pc into a hard reboot (hold power down for 5 seconds). When I bring it back up it starts scandisk again and will not stop this cycle! Is there anyway to advert this so I can run scandisk occasionally? I've done three reinstalls of windows and still can't get it to work properly! I tried to got into safe mode still doesn't work. I even tried to fix the MBR even though it should not have effected it! WHAT CAN I DO?
MMock is offline   Reply With Quote
Old May 29th, 2002, 06:14 AM     #2 (permalink)
ben-the-slacker's Avatar
I'm confused.
Why would you reboot after you schedule a scandisk? I though the system only needs to reboot after scandisk is complete...
ben-the-slacker is offline   Reply With Quote
Old May 29th, 2002, 09:18 AM     #3 (permalink)
ben
On windows XP when you tell it to do a scandisk. It will throw a box up at you saying that there are system files in use. You need to restart your computer to do a scandisk.
I don't know what is causing the problem. With that many reloads and all the other items you have done.
The only suggestion I could make would be to find the scandisk.exe file on your cd. Then do a copy and paste and replace the file in the system folder. It could be windows istaller went nuts when you installed XP.
Philip1952 is offline   Reply With Quote
Old May 29th, 2002, 10:13 AM     #4 (permalink)
Inanis's Avatar
I think . . .
Hard drive failure causing scandisk to lockup . . causing scandisk to run again..
How ironic, lol
Are you using NTFS? Try that instead of FAT32 if you havent already.
Try doing a low level format and check of the hard drive, as well.
Inanis is offline   Reply With Quote
Old May 29th, 2002, 11:23 AM     #5 (permalink)
Where's the beef?
Scott Tiger's Avatar
Whoa... You can probably get a disk utility from the manufacturer of your hard drive that will work outside of Windows. I'd try that first. Doing a low level format will wipe off all data before you have any chance of getting anything off the drive. That's what I'd do if I suspected a hard drive problem...
Where's Lunch?
Scott Tiger is offline   Reply With Quote
Old May 29th, 2002, 01:23 PM     #6 (permalink)
MMock's Avatar
thanks for your help guys! Ill let you all know of my progress when I decide to run scandisk again!
Is It Just Me? (3063)
Delete an OS (17)
Nvidia GTX 260 problem (9)
Internet Lost (5)
How to converter MTS Video to HD mpeg.. (0)
Can a page file be "too big".. (0)
Looking for new motherboard (0)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
