Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 44
Thread: Useful apps
  1. #21
    Mar 2007
    My own little world.
    11,764
    Revo - uninstaller...
    Download Revo Uninstaller Freeware - Free and Full Download
    (I actually went to this thread to find a link, couldn't find it - but it has been mentioned in numerous threads and has worked...)
  2. #22
    I Haz Catputer JLK03F150's Avatar
    GA
    5,494
    Memory apps for checking & tweaking RAM sub-timings. Memset for Intel chipsets prior to IMC CPUs and CPU-Tweaker for CPUs with an IMC (Integrated Memory Controller).
    XtremeSystems Forums - View Single Post - New Memory Tweaker for Intel Chipsets
    Driver Cleaner Pro is no longer freeware & can't be downloaded anymore without buying it. The guys at Guru3D have Driver Sweeper, but I've never tried it.
    Guru3D - Driver Sweeper (no installer) download from Guru3D.com
  3. #23
    Feb 2007
    Springfield
    13,490
    5
    FAQ's ~ Team Stats
    My PC
  4. #24
    Dec 2008
    East Chamunga
    2,362
    Kristal Audio Engine: [Link]
    A simple Free Digital Audio Workstation
    ◄ it is what it is ►
  5. #25
    Dec 2008
    East Chamunga
    2,362
    Wavosaur: [Link]
    A great Free audio editor
  6. #26
    Dec 2008
    East Chamunga
    2,362
    Switch Audio Converter [Link]
    A Free high quality converter
  7. #27
    Member Gomar's Avatar
    Oct 2007
    NYC
    105
    Free burner:http://www.burnaware.com/Free
    pic viewer:IrfanView - Official Homepage - one of the most popular viewers worldwide I use Winrar much more often than Winzip.Winamp 5.541
  8. #28
    Mar 2007
    11,764
    Hi, not so much of a suggestion, but...
    Does anyone know of a good (free) DVD playing application...? Just been trying VLC but it isn't doing the trick...
    Oh, and just realised that AVG is missing from the list too...
    AVG Antivirus and Security Software - Real-time protection against viruses, spyware and malicious websites
    (or AVG Free - Download Free Antivirus and Antispyware for Windows 7, Vista and XP for the free version)
  9. #29
    USA
    18,373
    Give Jet Audio a try, once configured right it plays DVD's fine, have been using it for years, but I'm not too picky about my DVD software as long as it plays with out artifacting, slow frame rates, or reduced image quality.
    but its worth a try... should also add it to the free apps as well
    JetAudio
    the Basic version is the free one.
  10. #30
    Mar 2007
    11,764
    About time for an update or three..
    CDBurnerXP - CDBurnerXP: Free CD and DVD burning software
    Burns all sorts of disks, for audio or data...I've used it for CDs and DVDs, but it can also do Blu-Ray and HD-DVD disks, according to the site
    LastFM - Last.fm - Listen to free music with internet radio and the largest music catalogue online
    Non-install audio streamer where you can choose your own tracks; by artist, genre or their suggestions based on what you like
    AVG - AVG - Antivirus and Internet Security | Virus Protection [or AVG Free - Antivirus Download | Free Virus Protection for the free version]
    AntiVirus software, I use it on all of my [non-server] M$ machines
    Avira - Avira AntiVir Personal - Free Antivirus
    Another AntiVirus program - while not one that I've used, I have heard many good things about it from other technophiles...
    There are prolly a few more, but that'll do until Aaron updates the OP...
  11. #31
  12. #32
    Mar 2007
    11,764
    Oh, forgot to add Notepad++ (but I don't have a link - I'm on the BlackBerry), really good text editor, doesn't lose formatting with some TXT and LOG files like Notepad does...and it will 'cache' files that weren't closed before the app was killed..
  13. #33
    GA
    5,494
    Quote Originally Posted by Nude_Lewd_Man View Post
    AVG (free) is the pits. The AV2009 malware can break AVG without even getting fully installed. They must have found an exploit in AVG.
    Avira is a much better AV program. Fewer false positives and a better detection rate.
  14. #34
    Nov 2006
    Portsmouth, UK
    4,162
    Will update on the W/E.
  15. #35
    USA
    18,373
    Need to remove the Driver Cleaner Link in the Drivers Category for Cleaning GPU Driver Bits, etc, as Guru3D no longer supports it, and has deleted any and all Download links for it.
    Something about latest versions had many ad pop ups in the installer and since they were strongly against any of that, they were waiting for the guy who made it to remove them, guess things didn't pan out well (this was back in October of last year), even the thread in their forums about the program, is dead as of October 2010, no recent postings.
    so can safely say to remove that link from our list.
  16. #36
    Mar 2007
    11,764
    Seems to be a dead thread...
    I'm guessing that this didn't happen, as the OP shows:
  17. #37
    Banned
    Feb 2009
    KFNL FS2004
    11,886
  18. #38
    Mar 2007
    11,764
    Oh, that reminds me of a link (purely web-based, but can be very handy in troubleshooting [incoming] DNS issues)
    MX Lookup Tool - Check your DNS MX Records online - MxToolbox
    You can check MX Records, do DNS/NS searches and run a WHOIS on it...some of this can be done from the CLI anyway, but this has a good GUI and offers one-click next steps...
  19. #39
    Banned
    Feb 2009
    KFNL FS2004
    11,886
  20. #40
    Mar 2007
    11,764
    Looks like this hasn't been updated for a while....so consider this a free BUMP..!!
    Also, what are some good backup apps that are available (both free and paid) that can be added...
    (If Aaron doesn't, then I will)
What planet do we live on?
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. 32bit apps vs 64bit apps
    By TheBigCarp321 in forum Applications and Operating Systems
    Last Post: January 18th, 2007, 08:38 PM
  2. OS install + Apps
    By PyroSama in forum Applications and Operating Systems
    Last Post: September 8th, 2005, 01:09 PM
  3. 64bit apps?
    By eneki in forum Applications and Operating Systems
    Last Post: July 21st, 2005, 06:10 PM
  4. Garageband-like apps for PC?
    By fapbuh in forum Applications and Operating Systems
    Last Post: June 24th, 2004, 11:05 AM
  5. Must-have FREEware apps?
    By ablang in forum IMO Community
    Last Post: September 7th, 2002, 02:23 AM
