Remove a program in the Uninstall Programs List. Help.
Currently Active Users: 2651
Discussions: 203,417, Posts: 2,407,426, Members: 248,942
Old June 21st, 2009, 07:21 AM   Digg it!   #1 (permalink)
Top Gun's Avatar
Send a message via Yahoo to Top Gun
I have permanently deleted a program manually (Bethesda\Fallout 2) but before I just found out it had an uninstall option in the Uninstall Program List in the control panel. Now my problem is how can I manually remove the Program (Fallout 2) from the Uninstall Program List so that it would not show up. Thanks!
My specs:
Intel Core 2 Quad
7 GB Ram
Ultimate VISTA 64bit SP2
160 HDD
512MB 8900 Nvidia Geforce
Never interrupt your enemy when he is making a mistake.
Top Gun is offline   Reply With Quote
Old June 21st, 2009, 07:28 AM     #2 (permalink)
Ride 'em Cowboy
Description of the Windows Installer CleanUp Utility
Have you hugged your kid today??
Steve R Jones is offline   Reply With Quote
Old June 21st, 2009, 07:40 AM     #3 (permalink)
Top Gun's Avatar
Thanks for the link but can u provide me a step by step manual removal. I think its by using a regedit or something. Thanks!
Old June 22nd, 2009, 06:36 AM     #4 (permalink)
Ride 'em Cowboy
Install the application
Launch the application
Look for Bethesda\Fallout 2 and remove it/them.
Old August 1st, 2009, 04:03 AM     #5 (permalink)
Top Gun's Avatar
The application you have provided me did not detect Fallout 2 or Bethesda.
Old August 1st, 2009, 07:25 AM     #6 (permalink)
Ride 'em Cowboy
Mr Google helped me find the following for XP...If it doesn't work for Vista it should steer you in the right direction.
How to manually remove programs from the Add or Remove Programs tool
Old August 1st, 2009, 11:00 PM     #7 (permalink)
Imperion1's Avatar
You can also download and install Revo Uninstaller. It works pretty good uninstalling bad installs, or programs no longer installed but still in the add-remove programs list.
Imperion1 is offline   Reply With Quote
Old August 1st, 2009, 11:47 PM     #8 (permalink)
voids warrantys
KarmaKiller's Avatar
CCleaner also has that function, as well as a slew of other very useful ones.
Q6600@4Ghz | I7 920@4.3Ghz | E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
Old August 2nd, 2009, 10:51 AM     #9 (permalink)
Top Gun's Avatar
OK thanks for the help. I'll get to you guys as soon as i tried all the applications you have mentioned.
Old August 2nd, 2009, 11:17 AM     #10 (permalink)
Top Gun's Avatar
Just used Revo Uninstaller and it worked!!! thanks guys.
no remove button in add/remove programs keitkeit Applications and Operating Systems 2 March 13th, 2008 02:18 PM
a program will not uninstall from add/remove tumutlass General Tech Discussion 5 November 5th, 2007 10:38 AM
How to remove program "entry" from remove programs Trophy1 Applications and Operating Systems 6 September 15th, 2005 07:06 PM
Missing programs in Add/Remove Programs eweruk Applications and Operating Systems 6 April 19th, 2002 03:00 PM
Removing programs from program list mad1 General Tech Discussion 12 November 27th, 2001 10:56 AM
Is It Just Me? (3731)
and she wanted to be VP? (59)
nVIDIA GTX 260 vs ATI 5770 (6)
GPU upgrade from 8600 GT (14)
Superbowl commercials (The green po.. (15)
New PC Heavy Gaming Rig (9)
[F@H Chat]2/6/10 New thread for ya'.. (25)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
Graphene transistors promise 100GHz.. (7)
Animated GIFs don't animate? (13)
I want to buid a pc with this case (14)
Upgrading (5)
How Good is This $450 MSI Laptop? (4)
should i upgrade whole pc or just vid.. (3)
[F@H Chat]2/6/10 New thread for ya' s.. (25)
tecumseh snow blower (0)
PLEASE MUCH NEEDED HELP! (4)
Information on the Foxconn RC4107MA M.. (5)
3 monitors (1)
HD5870 Question (18)
Microsoft Wireless Keyboard 3000 (13)
Laptop - HDTV Connection Using HDMI C.. (2)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
