Need Technical Expierience  | | |
July 6th, 2009, 02:38 PM
#101 (permalink)
| Quote:
Originally Posted by ShyguyXPC |
Very nice. unless i will have to format my HD next time i post here will be on my new computer  |
July 6th, 2009, 04:56 PM
#102 (permalink)
| | PC Upgrade Procrastinator
yep, you'll want to reformat your hard drive anytime doing a major system upgrade like this, to get best performance out of the system.
especially if your going to be running Windows 7 RC on it, you'll want to reformat the drive and install the OS. Just make sure to back up any important data first (to another Hard drive or Recordable CD/DVD media)
__________________ Quote:
July 6th, 2009, 05:20 PM
#103 (permalink)
Im hoping to use the windows pro we have.
So when i put my HD into the computer after everythings hooked up, will it like auto format? |
July 6th, 2009, 06:45 PM
#104 (permalink)
Other than that, how can the video card compare to a Nvidia? Specifically the 8600 and 9500, but i'd like to know generally. Thanks guys for your help. |
July 6th, 2009, 07:39 PM
#105 (permalink)
Radeon 4670 competes generally with the Geforce 9600GT, which is more than double the performance of a Geforce 8600/9500GT.
as to the hard drive, if you have the windows disc/discs, after installing it, you'll want to reboot from disc and wipe the drive clean, reformat, partition (or is it partition, reformat, forget off hand), then install a clean install of windows to the newly formatted disc.
otherwise you might be able to do a repair install of Windows on the hard drive, basically uninstalls/installs old/new chipset drivers, GPU and whatever else drivers, and lets you retain your existing install of windows intact. though if your having any problems software wise, or virus's, spyware, etc etc, now, it'll follow over to the new system, especially if the hard drive is heavily fragmented, lowering performance as well.
Look here: Tom's Hardware - Benchmark Mass Effect
middle one is the 4670. (it really depends on the games run, some favor ATI, others Nvidia)
July 6th, 2009, 08:12 PM
#106 (permalink)
thank you  my friend has a 9500 low profile but could play ETW pretty well. |
July 8th, 2009, 04:05 PM
#107 (permalink)
Ok yesterday my computer failed on me, it took over 24 hours to get it back up and running >_>.
ANYWAY i got my NEW computers case, thanks to stupid ass UPS in order to make sure the rest of it is OK i have to check outside every 15 minutes. They left my case outside without ringing the doorbell or nothing -_-. |
July 8th, 2009, 04:37 PM
#108 (permalink)
And um how am i supposed to put sound on this??? I just thought of that lol, if i format will my old sound disk work? |
July 8th, 2009, 08:00 PM
#109 (permalink)
when you reformat your system, you install the onboard audio drivers with the chipset drivers and use the onboard audio chip. or you if you have a Home Theater or HDTV with HDMI ports you can use the Radeon to Process HD Audio and plug in an HDMI cable from the card to the Receiver or TV and get audio that way.
Either way when you reformat the system you'll install the drivers and control panel software to use the onboard or GPU audio. |
July 11th, 2009, 01:15 AM
#110 (permalink)
YAY THIS COMPUTER IS THA SHIT!!!!
it was a bitch to put together and sumthings wrong with the HD audio. Otherwise, pretty sexy so far :P. |
