Is this a decent gaming system???  | | |
July 2nd, 2009, 09:03 AM
#11 (permalink)
Ok, Thanks for all the advice. I have decided just to use some old XP64bit I have lying around. Then I will upgrade to 7 when I can get full version. Or if I'm too lazy ill just go for the 64bit 7 release candidate, and upgrade from there. I don't want to go back to using vista.
I have decided to scrap the raptor, as it goes over my budget which is already stretched. So instead I have just gone for 3 Samsung 1TB's, which will last me for ages in terms of space. Unless there is a similar HD wich is similar in price but better in any other way.
Also, as I am not really planning to overclock (im scared ill wreck some of my parts if I mess around with them haha), I have gotten rid of the Asus mobo, and switched to a Gigabyte GA-EX58-UD4P LGA1366, X58, which seems to have a fairly good reputation, and it also saves me a bit of $$$.
Finally, I also downgraded to a eVGA GTX260+SSCEDITION, which is considerably cheaper from the price source I am using.
Thanks again    |
July 2nd, 2009, 09:19 AM
#12 (permalink)
Oh and I have also changed the case. Going for the CM HAF 932 now XD. Is there any point to grab another brand CPU cooler for the i7? |
July 2nd, 2009, 09:28 AM
#13 (permalink)
| | \m/(°-°)\m/
| Quote:
Originally Posted by pullmyfoot the only reason I know is because I entered myself into a competition to win one last week  | *offtopic*
I entered to win one a while ago, haven't heard anything back.
Did you enter to win the TKWR's AMD chips at Toms? Limited edition AMD Quad core that's estimated value is $999!
(entered that one too)  Quote:
Originally Posted by ihaveacrappydell Oh and I have also changed the case. Going for the CM HAF 932 now XD. Is there any point to grab another brand CPU cooler for the i7? | I personally won't use a stock cooler. That's more of a personal preference though. A good after market cooler will cool better, and probably be more quiet. If budget is a factor though, it's not needed. |
July 2nd, 2009, 10:14 AM
#14 (permalink)
| Quote:
Originally Posted by KarmaKiller I personally won't use a stock cooler. That's more of a personal preference though. A good after market cooler will cool better, and probably be more quiet. If budget is a factor though, it's not needed.  | Ok, ill keep that in mind. Might go for a thermaltake CPU cooler if I can find one for a good price.
Thanks  |
July 2nd, 2009, 10:18 AM
#15 (permalink)
| | \m/(°-°)\m/
July 2nd, 2009, 10:34 AM
#16 (permalink)
July 2nd, 2009, 11:51 AM
#17 (permalink)
| | Super Duper Member
| Quote:
I personally won't use a stock cooler. That's more of a personal preference though. A good after market cooler will cool better, and probably be more quiet. If budget is a factor though, it's not needed.  | nope. Local competition
to the original poster, the Gigabyte board you chose is very good
__________________ PII 720BE X3 @ 3.7Ghz | Gigabyte 790GX | HD4850 | 4gigs OCZ Reper | WDC 640gb Black Athlon II 250 X2 @ 3.80Ghz | Gigabyte 770 | HD4670 | 4 gigs OCZ Reper |
July 2nd, 2009, 01:46 PM
#18 (permalink)
| Quote:
Originally Posted by pullmyfoot nope. Local competition
to the original poster, the Gigabyte board you chose is very good  | Thanks for all the help then. Ill go for the Gigabyte board for sure. |
July 2nd, 2009, 02:19 PM
#19 (permalink)
| | Super Duper Member
| Quote:
Originally Posted by ihaveacrappydell Thanks for all the help then. Ill go for the Gigabyte board for sure.  | yep, and if you want to try, its still a very good overclocking board (pretty much all the X58 boards are since they are high-end products). |
July 3rd, 2009, 05:32 AM
#20 (permalink)
| Quote:
Originally Posted by pullmyfoot yep, and if you want to try, its still a very good overclocking board (pretty much all the X58 boards are since they are high-end products). | Ok, Well I'm really not sure how to overclock, unless its through a simple program or something similar, but I will give it a go.
Thanks |
