Does a monitor really effect gfx performance?  | |
July 2nd, 2009, 11:32 AM
I'm currently using a shitty CRT monitor, my 19" LCD monitor should be here from newegg in a few days and I'm wondering will it decrease my gaming performance and how? |
July 2nd, 2009, 11:46 AM
| | Ride 'em Cowboy
I vote you wait a few days and post back your results
The older LCD's were a bit slower in the refresh department...Odds are you won't notice any difference except for the part about having a nice new monitor
__________________ Have you hugged your kid today?? |
July 2nd, 2009, 12:03 PM
| | \m/(°-°)\m/
Normally when people say something along the lines of "this new monitor is killing my GPU" it's normally because LCD's run larger resolutions then what CRT monitors do. So you probably will take a performance hit in games, unless you turn down the resolution. |
July 2nd, 2009, 12:38 PM
| Quote:
Originally Posted by KarmaKiller Normally when people say something along the lines of "this new monitor is killing my GPU" it's normally because LCD's run larger resolutions then what CRT monitors do. So you probably will take a performance hit in games, unless you turn down the resolution. | I usually only run at 1024x728 for games and max for everything else. |
July 2nd, 2009, 12:47 PM
| | \m/(°-°)\m/
Yes, but your newer LCD will run at a larger res. Yes, you could turn it down, but it won't look good at all in games.
What monitor are you getting? What's the specs on your system.
EDIT:
Nevermind, I see you have another thread going for that.
July 2nd, 2009, 11:25 PM
| | PC Upgrade Procrastinator
if you end up buying that 4830 from your other thread, you shouldn't have too much to worry about unless that new LCD is running 1920x1080 or 1920x1200 or larger resolutions, but then depends on the games run too.
__________________ Quote:
July 2nd, 2009, 11:35 PM
| Quote:
Originally Posted by endrien I'm currently using a shitty CRT monitor, my 19" LCD monitor should be here from newegg in a few days and I'm wondering will it decrease my gaming performance and how? | Its 19" depending on whether it is widescreen (1440x900) or standard 4:3 (1280x1024). Both resolutions are larger than what you are using now.
July 5th, 2009, 12:44 AM
Should be getting my new monitor like moday or so, I'll see what happens |
