Budget PC Build, first time - Need Advice
Currently Active Users: 2166
Discussions: 200,897, Posts: 2,378,783, Members: 246,267
Old July 4th, 2009, 12:30 AM   Digg it!   #1 (permalink)
Hello there,
I've recently decided that I would like to build a budget gaming rig to replace my near 3 year old laptop which is performing with new games like I would expect it to after being around for 3 years. I've researched a bit about quality parts for less money, and I think I may have put together a decent build, but since this is my first time actually building a computer myself, any input you guys have would be great. I was trying to keep the budget under or around $700, but if I have to buy vista which it looks like I will, then its going to go way above $800.
CPU AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail - $189.99 Free Shipping
MOBO ASUS M4N72-E AM2+/AM2 NVIDIA nForce 750a SLI ATX AMD Motherboard - Retail - $134.99 Free Shipping
I got the Mobo and the CPU on a combo deal for $289.98, although I'm not sure if the Asus I chose is really necessary, and a Gigabyte might be more suitable.
CASE w/ PSU RAIDMAX SMILODON ATX-612WBP Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case With 500W Power Supply - Retail $89.99, $20 MIR
GPU HIS H487FN1GP Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail $149.99, $20 MIR
RAM OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2N800SR4GK - Retail $45.99, $10 MIR
DVDRW SAMSUNG 22X DVD±R DVD Burner Black IDE Model SH-S222L LightScribe Support - OEM $25.99
HD Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM $59.99
The total comes out to about $681.92 not including tax and shipping, because I'm getting a wireless network card as well.
Do you guys see any place where I can cut costs? Is the mobo I picked out necessary? I know people usually advise against using the PSU that comes with a case, but is a 500W PSU good enough for the rig I have set up? Thanks in advance.
Trayus is offline   Reply With Quote
Old July 4th, 2009, 12:45 AM     #2 (permalink)
endrien's Avatar
Generally with Case/PSU combos the PSU is total garbage so I wouldn't advise using it with you system, unless you can confirm that it's a trusted good brand.
endrien is offline   Reply With Quote
Old July 4th, 2009, 12:47 AM     #3 (permalink)
Aaron_8015's Avatar
Send a message via MSN to Aaron_8015 Send a message via Skype™ to Aaron_8015
Welcome to techimo.
Firstly I would suggest you pick up a caviar black, which is a fast HDD
Newegg.com - Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - Internal Hard Drives
Also I would scrap the case/PSU combo, and get a good quality PSU
Newegg.com - OCZ StealthXStream OCZ500SXS 500W ATX12V / EPS12V Active PFC Power Supply - Power Supplies
Case is your preferance.
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900
''I dont suffer from insanity. I enjoy every minute of it.'
Aaron_8015 is online now   Reply With Quote
Old July 4th, 2009, 12:57 AM     #4 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Hi and welcome to TIMO.
My suggestions.
1. Indeed drop the board and get this instead
Newegg.com - GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - AMD Motherboards
You won't be disappointed. It's not that the board you picked out "isn't needed", it's the fact that the gigabyte board has much more "bang for buck" value IMO. It's really a great board.
2. While 500watts is more then enough for your system, Raidmax PSU's are junk. I really wouldn't trust that PSU in my brand new system.
Newegg.com - OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Power Supplies
That is a great PSU, with free shipping, and it's only $50 after rebate. (which don't hold your breath for, but you'll get it eventually)
3. This is really a more personal preference thing I guess, but I really think you could do better on your case. If you like the lights and "bling" then I guess that's one thing. But the build quality of those cases usually are lacking.
Newegg.com - COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Computer Cases
This case is cheaper, has free shipping, and is actually really well made. They have a version of that same case without the side window for $50 with free shipping. But I'm guessing you like the window, so that's a good option. You can always stick colored fans/light/etc in later to get the look your going for.
4. I'd step up to this ram
Newegg.com - OCZ Fatal1ty Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2F10664GK - Desktop Memory
It's faster, and I'm guessing your probably gonna OC this system at some point, that ram will do the job nicely.
5. Step up to this HDD
Newegg.com - Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - Internal Hard Drives
It's more yes, but it's larger, and way faster then the 500Gb HDD. It's worth it.
6. DO NOT BUY VISTA!
You can download the RC of Windows 7 for free, and it's good till the retail version releases. I've been on it for months, so have many others, and the general conciseness is it's awesome. It's MUCH better then Vista, faster, looks better, less of a resource hog, just all around better. And it's FREE!
When they release Win 7, pick that up. You'll be much happier.
That's all.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
KarmaKiller is online now   Reply With Quote
Old July 4th, 2009, 12:59 AM     #5 (permalink)
Aaron_8015's Avatar
Well KK added more, was busy playing game.
Old July 4th, 2009, 01:27 AM     #6 (permalink)
My suggestions.
That's all.
Thanks a bunch for the input. I actually only picked that Case because it came with a 500W PSU and I figured it would be better to knock out two different parts for under 100 if the PSU was decent. The lights and stuff was just extra I guess. I looked at the case you recommended and saw a combo deal with a 460W PSU for 75, is that PSU powerful enough for the build or should I stick with the 500W?
As for the Windows 7, I read on Microsoft that on March 1st 2010 the OS starts shutting down every 2 hours which seems really annoying, and they recommend you revert to an older, genuine OS, but I'm not sure when Windows 7 is supposed to be released or how much its supposed to cost, not to mention the fact that I don't have another copy of XP or Vista.
Old July 4th, 2009, 01:34 AM     #7 (permalink)
\m/(°-°)\m/
Well I see your point. And all I'm trying to say if you buy vista now, when you see windows 7, your gonna be upset you wasted you money on it. I'm not sure what to tell you about that. Maybe you can find a copy of XP or the like for cheap before then??
And I'd stick with the 500w I linked to, mainly because it has both a 6 pin, and a 6+2 pin that you'll need for you video card. Other wise you'll have to use adapters.
Old July 4th, 2009, 01:35 AM     #8 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
Windows 7 is being released in Oct so no worries there. You can use the beta until then or at the very least if you do buy Vista make sure it comes with a free upgrade
It looks like the combo you spotted was with the cooler master rs 460 thats not a bad PSU but it doesn't have all the connections needed for the gpu and the extra overhead of a 500w psu is nice.
If you are really that worried about staying on budget you could go with this combo you are basically getting the board free amir
edit: The other thing to throw in there too is if you plan on doing any overclocking you'll want to get an aftermarket cooler.
Linus Torvalds
RicheemxX is online now   Reply With Quote
Old July 4th, 2009, 01:46 AM     #9 (permalink)
How does the BIOSTAR mobo compare with the GIGABYTE?
Old July 4th, 2009, 02:08 AM     #10 (permalink)
RicheemxX's Avatar
Here's the side by side comparison the Gigabyte has a few extra features and an additional 16x pci-e slot but they should both be pretty solid boards.
Budget Build dzee General Tech Discussion 6 May 30th, 2008 08:36 PM
New Build on a Budget [dnb]junglist General Tech Discussion 11 March 4th, 2008 07:56 PM
Need advice on a budget build Monstermile General Tech Discussion 16 November 8th, 2007 04:36 PM
New Build Time, need lots of advice Gib General Tech Discussion 2 June 5th, 2006 06:52 PM
Advice for a 1st time build starrboy General Tech Discussion 11 August 2nd, 2002 08:35 PM
Is It Just Me? (2773)
A good PSU? (9)
California Passes Anti-Flat-HDTV Le.. (37)
$1M sports car driven into marsh af.. (38)
Print spooler problem (5)
Dept. of HS: NSA 'Helped' Develop V.. (11)
EVGA 9800 gtx help with finding a g.. (5)
Mysterious Boot manager (9)
Ideal cheap graph card for PC-Gamin.. (12)
New Build the Montior is blank (8)
8800 GT 512 and 9800 GT 512 SLI (12)
World's largest Monopoly Game using.. (328)
hybernate option (2)
Foreign voltage (1)
A good PSU? (9)
blender help (2)
Hard drive freezes boot (1)
Dept. of HS: NSA 'Helped' Develop Vis.. (11)
System recovery disk maker (2)
Like New Wacom 12x19 Intuos 3 + Grip .. (1)
windows 7 internet problem (3)
EVGA 9800 gtx help with finding a goo.. (5)
Skillsoft Network+ Study Software Que.. (8)
Ideal cheap graph card for PC-Gaming? (12)
Internet very slow since updating AVG.. (13)
Divx for vob to mkv (0)
Help:Cant play MP3 burnt CDs on my Ch.. (5)
XP Pro freezes on HP Media Center pc (0)
I want to add a floppy to my PC (20)
