fans spin, not much else happens  | |
July 5th, 2009, 09:23 PM
This is my first time building a computer and obviously i've run into some problems.
I have a brand new mobo, cpu (stock intel heatsink and fan), ram, PS and am using a less than 1 year old 8600gt graphics card, and less than 3 month old wd hard drive.
I managed to put everything together in what i thought was the right way but then when i went to power it on the fans spun for about 12 seconds, all the lights on the case lit up, so did the light on my optical drive and i was able to open and close the tray, but then it just shut off, and a few seconds went by then it would do the same thing over and over until i shut off the power supply. I' tried removing the cpu and heat sink and when i did that the computer stayed on but i didn't get any output on my monitor. I know it's probably a very stupid question but does a computer still post without a processor? i figured id get some type of bios screen. So now i'm thinking that both my processor and video card are bad. Can anyone with some experience give me some advice? |
July 5th, 2009, 11:01 PM
| Quote:
Originally Posted by agroupofletters This is my first time building a computer and obviously i've run into some problems.
I managed to put everything together in what i thought was the right way but then when i went to power it on the fans spun for about 12 seconds, all the lights on the case lit up, so did the light on my optical drive and i was able to open and close the tray, but then it just shut off, and a few seconds went by then it would do the same thing over and over until i shut off the power supply. I' tried removing the cpu and heat sink and when i did that the computer stayed on but i didn't get any output on my monitor. I know it's probably a very stupid question but does a computer still post without a processor? i figured id get some type of bios screen. So now i'm thinking that both my processor and video card are bad. Can anyone with some experience give me some advice? | Make sure EVERYTHING is connected. When I cleaned out my computer I forgot to plug one small cable into the motherboard and all it did when I powered on was rev the fans/dvd drive. |
July 5th, 2009, 11:38 PM
i checked, and to the best of my knowledge everything is plugged in. there are very few empty connections left on my motherboard. |
July 6th, 2009, 02:27 AM
Take the whole system out of the case, assemble on a no conductive surface and try to boot with minimum components. I.e. Mobo, CPU, PSU, 1 stick of memory, use on-board video if you have it. NO DVD or HDD drive.
Also a list of exact parts will be helpfull, (PSU importantly).
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | No screen display, no boot, but fans spin | baby mama | Technical Support | 5 | September 27th, 2008 12:14 PM | | Board gets power (fans spin) but no POST | sm8000 | Motherboards | 11 | October 7th, 2007 12:26 AM | | A new spin on an old problem | Chromeo | Technical Support | 7 | July 20th, 2007 04:06 AM | | Computer boots, Fans Spin, No Beep, Nothing else turns on????? | _Switch_ | Technical Support | 24 | August 19th, 2005 08:57 PM | | No fans, no spin ups, JUST green ASUS board light | buddhafest | Technical Support | 20 | February 4th, 2003 04:57 PM | |
