Yup. Generally the command line to load a data file along with a program is just to put it on the command line, e.g. d:\programs\wp\wordperfect.exe c:\mywpfiles\myfilename Some programs may need a switch like /loadfile=myfilename but most don't. The /? or /help as mentioned above should display the list of parameters available. You may also need the file's location as well unless the program has had its file location setting set to where you actually keep your data files.
.bh.
