I just built my first computer 2 months ago and it's been running excellent. I want to get a nice video card for better graphics in WOW and Aion but I need a higher wattage power supply.
I ordered a higher wattage (650w) PSU on the internet and received it today. I currently have a 450w. I installed it and my system will not turn on at all. The green motherboard light comes on, but when I press the power button it flashes and the fans spin once then stop. Nothing happens after that.
I tried turning it on with the screwdriver test and it did the same thing. I also tried taking the battery out to reset the BIOS for 5 minutes then putting it back in. No luck there either.
I then decided to put my old PSU in and the system starts up with no issues at all. Is the power supply I received bad or is there another issue?
Thanks for your help
Well I don't want to spend more that $150. I was looking at the 9800 GTX (doesn't matter the what the maker is EVGA, PNY, etc.) DO you have any suggestions?
