whats the difference
Currently Active Users: 2278
Discussions: 200,959, Posts: 2,379,538, Members: 246,329
Old June 11th, 2002, 11:14 PM   Digg it!   #1 (permalink)
eskippyca's Avatar
Send a message via MSN to eskippyca
Lightbulb
so whats the difference between the left and right mouse bottons ?
safe surfin the big skip
eskippyca is offline   Reply With Quote
Old June 11th, 2002, 11:17 PM     #2 (permalink)
Misanthropic
Depending what you're doing, each button has a different purpose.
Maybe someone can go into greater detail.
Mike is offline   Reply With Quote
Old June 11th, 2002, 11:18 PM     #3 (permalink)
jerrygarcia's Avatar
Send a message via AIM to jerrygarcia Send a message via Yahoo to jerrygarcia
It depends on if you're right or left handed. Whatever way you want to set it up in your hardware.
jerrygarcia is offline   Reply With Quote
Old June 11th, 2002, 11:21 PM     #4 (permalink)
KenKun's Avatar
They are the same ..using them depends on how you configure the method of usage for each ..
KenKun is offline   Reply With Quote
Old June 12th, 2002, 09:58 AM     #5 (permalink)
Steeler Fan
jman01pa's Avatar
By default the left button is used for selecting and the right button generally shows a menu of options for ther particular application.
By launching the Mouse icon in Control Panel you can change the default settings for your mouse. Most importantly you can reverse the left and right mouse buttons...
This is brief but hope it helps...
J
jman01pa is offline   Reply With Quote
Old June 12th, 2002, 10:10 AM     #6 (permalink)
Fossil
Theophylact's Avatar
If you've got a three-button or scroll mouse, your list of options becomes vast indeed. Logitech MouseWare includes a "Webwheel" function for web navigation as well.
Theophylact is online now   Reply With Quote
Old June 12th, 2002, 10:12 AM     #7 (permalink)
Re: whats the difference
Easy! One's on the left, the other is on the right!
EndobioticChaos is offline   Reply With Quote
Old June 12th, 2002, 10:48 AM     #8 (permalink)
eskippyca's Avatar
Re: Re: whats the difference
thanks for the enlitenment sir thats the answer i was looking for
Is It Just Me? (2970)
The disrespect of Obama by Russian .. (44)
Making Health Care Worse (180)
Print spooler problem (16)
Nvidia GTX 260 problem (0)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
