SpeedFan Temp Monitor Help
Currently Active Users: 1625
Discussions: 208,766, Posts: 2,468,832, Members: 254,495
Old February 8th, 2010, 01:26 PM   Digg it!   #1 (permalink)
I have speed fan 4.40 and dont know what temp 1 temp 2 and temp 3 mean?
Win9x:NO 64Bit:NO GiveIO:YES SpeedFan:YES
I/O properly initialized
Linked ISA BUS at $0290
Linked ATI SBx00 SMBUS at $0B00
Scanning ISA BUS at $0290...
SuperIO Chip=IT8718F
Linked ISA BUS at $0228
Scanning AtiIgp SMBus at $0B00...
Scanning ISA BUS at $0228...
IT8718F found on ISA at $228
Found WDC WD7501AALS-00E8B0 on AdvSMART
End of detection
Says:
CORE 97F
HD0 84F
Temp1 86F
Temp2 104F
Temp3 100F
I have no idea what temp 1,2,3 are. How can I find out?
Also what temps should you monitor?
N8N8N8 is offline   Reply With Quote
Old February 9th, 2010, 12:46 AM     #2 (permalink)
Well, could be a lot of things. Anything that speedfan can pick up that has a sensor, it will report on. But the information regarding the sensor is provided by the device itself, not determined by speedfan.
One of them is likely motherboard temperature at the northbridge. The others could be mobo related too, or could be a PCI device that has a sensor. The fact that you have a core temp but not a cpu temp means that one of them could be cpu. Another is likely the gpu. So it's possible that you have temp 1, 2, and 3 as cpu, northbridge, gpu. Not necessarily in that order either.
You might want to look when speedfan initializes and find the address it's reporting the sensor on, then go through your device manager and look at the device information and try to match the address with what speedfan is looking at. A bit tedious, but otherwise I won't know for sure.
wambulance is offline   Reply With Quote
Old February 9th, 2010, 12:38 PM     #3 (permalink)
Smile
I figured it out. I cross referenced them to pc wizard.
Core
Hd
Temp 1 = processor
Temp 2 = mainboard
Temp 3 = power/aux
Old February 9th, 2010, 01:16 PM     #4 (permalink)
Cool, I guessed 2 out of 3 right.
Ask a Tech Question (free)!
Is It Just Me? (3018)
What Ever Happened to the Constitut.. (27)
inspiron 546 st PSU VIDEO CARD (18)
Exploit Rogue Scanner Infected My C.. (11)
Win 7 to Win XP (5)
FASTEST download speed ever (35)
Advice request for gaming computer pu.. (1)
GOLD!! Want gold from your old mother.. (5)
Exploit Rogue Scanner Infected My Com.. (11)
Heatsink fan? (4)
Problems starting a new build (2)
Folding with an SSD. (7)
Combo Deals (0)
Administrator User Account in Vista (0)
Should i put this graphics card in my.. (1)
GTX 460X1 or Radeon 5870 (2)
windows media center folders? (0)
UNKNOWN EMAIL ADDRESS (10)
I need to know what graphics card and.. (0)
Netgear WNHDE111 Router doesn't power.. (2)
The Government Can Use GPS to Track Y.. (5)
Failed to query TCP/IP settings (3)
SiliconJon's House of Warez (stuffFS) (5)
EZ Flash utility ain't so easy.... (1)
Internet Speeds (23)
PC Shuts down w/o prompt/restart. (1)
New to Linux? Check this out (66)
Ethernet Port not working (Enabled to.. (13)
TIME SENSITIVE! Dell Server RAID Clon.. (0)
Speedfan Temp 3 Dangerously high! SmackSmash Processors, Memory, and Overclocking 5 March 8th, 2010 06:12 PM
Temp Monitor & OC Vyx Processors, Memory, and Overclocking 11 February 12th, 2004 06:45 PM
Temp monitor iNeb PC Modification 7 January 18th, 2003 01:57 PM
Temp Monitor Brainchild Processors, Memory, and Overclocking 4 January 17th, 2002 09:50 PM
temp monitor jfwy Processors, Memory, and Overclocking 3 December 2nd, 2001 04:07 PM
TechIMO Copyright 2010 All Enthusiast, Inc.
