Page 1 of 2 1 2 LastLast
Results 1 to 20 of 29
    Jul 2010
    15
    logitech k120 keyboard not working
    Im new here
    My new usb keyboard is not working , but my ps/2 mouse works. I can't use my ps/2 keyboards because the ps/2 is damaged. It stops working at the loading screen. It works fine before it( I can access BIOS) and I go to the desktop fine( I don't need a password). It tells me to install , but when I do ..... it can't install. When I'm able to get to the BIOS the legacy usb keyboard is enabled .
    Note : I don't have the windows CD ROM with me and I can't access safe mode because it gets stuck at a certain point.
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Welcome to TechIMO!
    What happens, if you unplug it while the computer is running, and plug it into another USB port?
    Are there any alarms, in device manager?
    Hard Sayin Not Knowin
    Jul 2010
    15
    If I unplug it then plug it back in it still wouldn't work and I tried all usb ports. What do mean by alarms? Unless you mean it found a new hardware in the taskbar and it shows the icon and there's a yellow flag in the device manager.
    oh and thanks
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Yes, the yellow flag in device manager.
    What is the alarm for?
    If it is the keyboard, or USB controller, uninstall it, and restart the computer.
    Jul 2010
    15
    I did what you said it still wouldn't work at/after the loading screen then I tried to install still can't do it. It says it can't find necessary hardware.
    Back when my ps/2 was less damaged I think it stop working at the loading screen , but since it was damaged sightly I had to wiggle it around after the loading screen and it would work.
    Millwright
    Dec 2002
    New Hampshire
    8,189
    What was the alarm?
    Did it go away?
    Millwright
    Dec 2002
    New Hampshire
    8,189
    What operating system?
    Does anything else work in those USB ports?
    Jul 2010
    15
    I think I got you, me, or both confused. The yellow flag was a yellow ! mark beside a big question yellow mark where it said "USB keyboard" my mistake. Unless thats it. I'm pretty sure it would still be there.
    I forgot mention I need the keyboard to press F8 to go to debugging mode so I can get pass the login screen if not then it freezes there. If that somehow cause this keyboard problem . If not then I guess this problem( freeze at the login screen) doesn't matter.
    Jul 2010
    15
    hold on I check
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Quote Originally Posted by PcUser716 View Post
    Is this in device manager?
    Jul 2010
    15
    microsoft windows xp pro version 2002 serivce pack 3
    I think so I really don't have any to check besides my ps3 controller. Tried that can't install.
    And yes its in device manager
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Just a few more thoughts
    The legacy setting is only, so the USB keyboard, can run from the BIOS.
    Once the computer starts, Windows takes over.
    It is needed for DOS also.
    What happens, if you boot the computer without the USB keyboard plugged in, then plug it in after Windows starts?
    Windows has all the drivers for the keyboard, even though you may have software, with the new keyboard
    Are there any alarms next to the USB controllers, in Device Manager?
    Jul 2010
    15
    ok I try that
    Not; whats a DOS
    Millwright
    Dec 2002
    New Hampshire
    8,189
    You must be young, "Disk Operating System".
    It is what made Bill Gates a billionaire.
    It is what operated all Microsoft operating systems, until XP and NT.
  15. #15
    Millwright
    Dec 2002
    New Hampshire
    8,189
    One other thought, try disabling the PS2 keyboard, in device manager.
    I don't think it is the keyboard, because it works at start up, but try it on another computer to be sure.
  16. #16
    Jul 2010
    15
    Yes I'm 15 years old and a little ignorant with PCs . And thanks for telling me.
  17. #17
    Jul 2010
    15
    It worked on my other PC. I just to had simiply install it on the other one.
  18. #18
    Millwright
    Dec 2002
    New Hampshire
    8,189
    That's the way it should be.
    I've never seen a keyboard, that needed any additional driver, unless it has extra buttons.
    Even then, the standard parts work, without additional drivers.
  19. #19
    Jul 2010
    15
    It still wont work on the one I'm trying to do.
  20. #20
    Millwright
    Dec 2002
    New Hampshire
    8,189
    Did you disable the PS2 keyboard in device manager,?
    Is there one showing in Device Manager?
    edit;
    You never said, if there are any alarms, in Device Manager, next to the USB controllers or if there are any others, and what they are next to.
  1. Logitech S510 keyboard problems
    By Ximensions in forum General Tech Discussion
    Last Post: October 30th, 2006, 09:00 AM
  2. Logitech wireless keyboard...i-touch keys not working?
    By sweeper2 in forum General Tech Discussion
    Last Post: June 24th, 2005, 04:22 PM
  3. Just received my Logitech keyboard n mouse
    By golfcart in forum IMO Community
    Last Post: January 22nd, 2003, 06:07 PM
  4. Logitech Cordless Keyboard question
    By JimG in forum General Tech Discussion
    Last Post: January 10th, 2002, 12:05 AM
